Articulo: Power bank M1
Modelo/Marca: Generica
Especificaciones:
Waterproof, durable, rugged
Exterior is made with an easy-grip rubber
This item can be charged with solar power or with the included cable and used like a normal power bank!
Great for travelers or the outdoors!
Includes:
1 x 5000mAh Solar Charger
1 x Micro USB Cord
Instructions:
Green colored LEDs indicate when the unit is receiving energy from the sun: two LEDs in full sun, one LED in indirect sunlight, and none in darkness.
When charging from a USB port, all five LEDs light blue to indicate “fast” charging: four are blue steady and the fifth is flashing blue. When charging is complete, but the unit is still connected to a USB power source, all five LEDs light steady.
The unit takes longer (about 8 hours) to fully charge from the sun. A USB port will charge the unit in about 2-3 hours. It is a good idea to fully charge the unit from a USB port before the first use.
Charge status can be checked by pressing the switch once; up to five LEDs light blue (full charge). They go off by themselves in ten seconds.
When a fully charged unit is providing power to an attached device, all five LEDs light blue.
The LED light can be turned on by pushing the power button twice quickly or pushing and holding it down (depends on your model).
- Funcion de lampara de emergencia
- Linterna infrarroja
Precio de Inicio: Q50 :lock:
Negocio: Subasta
Tiempo de uso: Nuevo (0)
Tiempo ofrecido de Garantia: NO
Lugar de entrega y forma de pago: Zona 3 · efectivo contra entrega
- No hay compromiso de entrega a domicilio, centros comerciales, etc.
- Envios al interior son bajo responsabilidad del comprador y tienen un recargo de Q25 (adicionales al costo de la encomienda)
Duración/Finalización de subasta: 20/07/2019 - 11:59 pm
- Ofertas a la misma hora por el mismo monto, tiene precedencia la primera
- Ofertas a la misma hora, tiene precedencia la mayor
Pujas de: Q10 (y sus multiplos)
Estado general:
(Necesita reparación, solo p/repuestos, regular, bueno, excelente,
nuevo)
5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso.
4pts: COMO NUEVO, como nuevo significa, poco uso, puede faltarle su caja y manuales, pero debe tener accesorios y no rayones.
3pts: BUENO, bueno significa, que esta usado, pero funciona perfectamente, podria tener algunos rayones, le falta caja original y/o accesorios.
2pts: NECESITA REPARACION, significa que ya no cumple con alguna de sus funciones, tiene rayones y/o golpes significativos, le faltan piezas.
1pts: PARA REPUESTOS, significa que no funciona y se entrega tal y como esta.
- Reclamos dedido a desperfectos causados por accesorios defectuosos seran ignorados
- Los reclamos unicamente seran atendidos si el item lo vienen a recoger personalmente y prueban todas sus funciones antes de llevarselo
Teléfono o Contacto con el Vendedor: Pm * 5103-8833 *
WhatsApp
Fotos.
http://www.velocidadmaxima.com/forum...1&d=1563378249
http://www.velocidadmaxima.com/forum...1&d=1502569431
http://www.velocidadmaxima.com/forum...dmqvwxbz8p.gif
