Series de motor honda
q onda mucha, ya se q van a decir q q utas hace un :vwowner: x estos rumbos pero como de todo hay q saber en la vida vengo yo y pregunto, cuales son las diferentes series de motor que traen los hondas civic, crx, etc. en q se diferencian, q caballaje y torque tienen, datos asi! gracias por aclarar mi duda!!
Ok
1 Archivos Adjunto(s)
:ceja: ..... bueno, bajate el archivito que adjunte, alli esta la mayoria de codigos HONDA vos :vwowner:
En los post de abajo se los despliego mejor ..... lfkjdsakfjñl |
Series A B C
A16A1
The A16A1 was a carburated 1.6 liter engine used in 1986-1989 Accords in the non-USDM market. This engine was known as the EZ in 1984 and 1985, non-US Accords. Specifications • Carbeurated • Displacement: 1596 cm³ • Bore: 80 mm (3.1 in) • Stroke: 79.5 mm (3.13 in) • Power: o 88 hp (66 kW) @ 6000 rpm o 91 ft•lbf (123 N•m) torque @ 3500 rpm A18A The A18A engine was the 1.8 liter engine found in 1984-1987 Honda Prelude in the US. Abroad, it was also available in the 1986-1989 Accords. It was known as the ET1 in the 1984 and 1985 non-US Accords. Specifications • Carbeurated • Displacement: 1829 cm³ • Bore: 80 mm (3.1 in) • Stroke: 91 mm (3.6 in) • Power: o 110 hp (82 kW) @ 5800 rpm o 112 ft•lbf (152 N•m) @ 3500 rpm A20A The A20A is probably the most plentiful of all the Honda A-series engines. It was available in both carbeurated and PGM-FI versions. They were found in both Accords and Preludes throughout the 1980s. A20A1 & A20A2 The A20A1 and A20A2 were the carbeurated versions of the A20A engines. It was available in the 1984-1987 Honda Preludes as well as the 1982-1989 Accord DX and LX. They are the same engine, the only difference between them being that the A20A2 has no emissions components, so it has a slightly higher power output (hp and tq numbers for A20A1 only). Specifications • Exhaust: 4-1 Cast Manifold • Induction: Carbureted 2bbl Keihin ( Feedback Carb ) • Displacement: 1955 cc / 119 CID • Bore: 82.7 mm (3.26 in) • Stroke: 91 mm (3.6 in) • Power: o 98 hp (73 kW) o 109 ft•lbf (148 N•m) at 3500 rpm A20A3 & A20A4 The A20A3 and A20A4 were the fuel injected versions of the A20A engines. They were run by Honda's PGM-FI system on a partial OBD-0 computer. Again, there is no real difference between the A20A3 and the A20A4 besides the A20A4 having a slightly higher power output because of not having emissions components (hp and tq numbers for A20A3 only). The A20A3 was offered in the 1984-1987 Honda Prelude 2.0Si, the 1989 Honda Accord SE-i, and the 1986-1989 Honda Accord LX-i. Specifications • PGM-FI • Displacement: 1955 cm³ • Bore:82.7 mm (3.26 in) • Stroke:91 mm (3.6 in) • Power: o 1986-1987: 110 hp (82 kW) @ 5500 rpm & 114 ft•lbf (155 N•m) @ 4500 rpm o 1988-1989: 120 hp (89 kW) @ 5500 rpm & 122 ft•lbf (165 N•m) @ 4000 rpm (12 valve) B16A Note: All JDM OBD0 B16A engines are stamped 'B16A' (with no number after the "A" to identify version). • VTEC • Found in: o 1988-1993 JDM Honda Integra RSi/XSi (DA6/DA8) o 1989-1991 JDM Honda CRX SiR (EF8) o 1989-1991 JDM Honda Civic SiR (EF9) ? Displacement: 1595 cc ? Compression: 10.2:1 ? Rod/stroke ratio: 1.74 ? Power: 158 hp (118 kW) @ 7600 rpm & 111 ft•lbf (150 N•m) @ 7000 rpm ? Transmission: S1/J1/Y1/YS1 o 1992-1995 JDM Honda Civic SiRII (EG6/EG9) ? Displacement: 1595 cc ? Compression: 10.4:1 ? Power: 170 hp (130 kW) @ 7800 rpm & 116 ft•lbf (157 N•m) @ 7300 rpm ? Transmission: S4C o 1992-1996 JDM Honda CR-X del Sol SiR ? Displacement: 1595 cc ? Compression: 10.4:1 ? Power: 158 hp (118 kW) - 167 hp & 111 ft•lbf (150 N•m) - 116 ft•lbf B16A1 • VTEC • Found in: o 1990-1991 EDM Honda CRX 1.6i-VT (EE8) o 1990-1991 JDM Honda civic type R o 1990-1991 EDM Honda Civic 1.6i-VT (EE9) ? Displacement: 1595 cc ? Bore×Stroke: 81.0×77.4 mm / 3.19×3.05 in ? Compression: 10.4:1 ? Power: 160 hp (120 kW) @ 7600 rpm ? Torque: 111 N•m (82 ft•lbf) @ 7000 rpm ? Transmission: Y2 B16A2 • VTEC o 1992-2000 Honda Civic EDM VTi (EG & EK) ? Displacement: 1595 cc ? Compression: 10.2:1 ? Power: 170 hp @ 7600 rpm & 111 ft•lbf (151 N•m) @ 7000 rpm ? Transmission: Y21 o 1999-2000 Honda Civic Si (EM1) ? Displacement: 1595 cc ? Compression: 10.2:1 ? Power: 170 hp (118 kW) @ 7600 rpm & 111 ft•lbf (151 N•m) @ 7000 rpm ? Transmission: Y21 S4C ? Bore: 81mm ? Stroke: 77.4mm o 1996-1997Honda Del Sol VTEC (EG) ? Displacement: 1595 cc ? Compression: 10.4:1 ? Power: 170 hp (118kW) @ 7600 rpm & 111 ft•lbf (151 N•m) @ 7000 rpm ? Transmission: Y21 B16A3 • VTEC • Found in: o 1994-1995 Honda Del Sol VTEC (EG) ? Displacement: 1595 cc ? Compression: 10.4:1 ? Power: 158 hp (118kW) @ 7600 rpm & 111 ft•lbf (151 N•m) @ 7000 rpm ? Transmission: Y21 B16A4 • VTEC • Found in: o 1996-2000 Honda Civic SiRII (Asian version) (EK) ? Displacement: 1595 cc ? Compression: 10.4:1 ? Power: 170 hp (127kW) @ 7800 rpm ? Transmission: Y21 B16A6 • VTEC • Found in: o 1996-2000 Honda Civic - South Africa VTEC (EK) ? Displacement: 1595 cc ? Compression: 10.2:1 ? Power: 158 hp (118 kW) @ 7600 rpm & 111 ft•lbf (151 N•m) @ 7000 rpm ? Transmission: Y21 B16B • VTEC • Found in: o 1997-2000 Civic Type R[EK9] ? Displacement: 1595 cc ? Compression: 10.8:1 ? Bore: 81mm ? Stroke: 77mm ? Rod/Stroke ratio: 1.84:1 ? Power: 185 hp (137 kW) @ 8200 rpm & 118 ft•lbf (160 N•m) @ 7500 rpm ? Redline: 9000 rpm ? Transmission: S4C With LSD B17A1 • VTEC • Found in: o 1992-1993 Integra GS-R (DB2) ? Displacement: 1678 cc ? Bore: 81 mm (3.2 in) ? Stroke: 81.4 mm (3.20 in) ? Compression: 9.7:1 ? Power: 160 hp (120 kW) @ 7600 rpm & 117 ft•lbf (159 N•m) @ 7000 rpm ? Transmission: Cable~ YS1 (Speculated to be the rarest USDM B motor with approximately 1500 1992 GS-Rs & 3500 1993 GS-Rs ever built. This engine is also speculated to possibly be the rarest of any Honda or Acura engine.) B18A • Non-VTEC • Found in: o 1986-1989 Accord Aerodeck LXR-S/LX-S (Japan) o 1986-1989 Accord EXL-S/EX-S (Japan) o 1986-1989 Vigor MXL-S (Japan) ? Displacement: 1834 cc ? Compression: 9.4:1 ? Bore: 81 mm ? Stroke: 89 mm ? Dual Keihin Carbs ? Power: 160 hp (97 kW) @ 6100 rpm & 128 ft•lbf (164 N•m) @ 4700 rpm ? Transmission: A2N5, E2N5 • This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine. B18A1 • Non-VTEC • Found in: USDM DA9 o 1990-1993 Acura Integra usdm "RS/LS/GS" ? Displacement: 1834 cc ? Compression: 9.2:1 ? Bore: 81 mm (3.2 in) ? Stroke: 89 mm (3.5 in) ? Programmed fuel injection ? Power: 90-91 Only: 130 bhp (97 kW) @ 6000 rpm & 111 ft•lbf (150 N•m) @ 5000 rpm ? Power: 92-93 Only: 140 bhp (100 kW) @ 6300 rpm & 117 ft•lbf (159 N•m) @ 5000 rpm ? Transmission: 90-91: S1, cable ? Transmission: 92-93: YS1, cable B18B1 • Non-VTEC • Found in: o 1994-2001 Acura Integra "RS/LS/GS" (DC2 ? Displacement: 1834 cc ? Compression: 9.2:1 ? Bore: 81 mm (3.2 in) ? Stroke: 89 mm (3.5 in) ? Power: ? 142 hp (106 kW) @ 6300 rpm & 127 ft•lbf (172 N•m) @ 5200 rpm ? Transmission: Y80/S80 B18C • VTEC • Found in: o JDM Honda Integra SiR-G • Power: • 185 hp (138 kW) @ 7,600 rpm • Rev-limit: 8,200 rpm • 130 ft•lbf (180 N•m) @ 6,200 rpm • Transmission Type: 4-speed auto tranny or 5-speed manual tranny with optional LSD • Displacement: 1797 cc • Compression: 10.6:1 • Bore: 81 mm (3.189") • Stroke: 87.2 mm (3.433") • Rod Length: 137.9 mm (5.429") • Rod/Stroke Ratio: 1.58 • Transmission: S80, Y80, S80 w/LSD, Y80 w/LSD B18C (Type R) • VTEC • Found in: o JDM Honda Integra Type R • Power: • 200 hp (150 kW) @ 8,200 rpm • Rev-limit: 8,900 rpm • 134 ft•lbf (182 N•m) @ 7,300 rpm • Transmission Type: 5-speed standard with LSD • Displacement: 1797 cc • Compression: 11.1:1 • Bore: 81 mm (3.189") • Stroke: 87.2 mm (3.433") • Rod Length: 137.9 mm (5.429") • Rod/Stroke Ratio: 1.58 • Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD) B18C1 • VTEC • Found in: o 1994-2001 Honda/Acura Integra GS-R (DC2 & DB8) • Displacement: 1797 cc • Compression: 10.0:1 • Bore: 81 mm (3.189") • Stroke: 87.2 mm (3.433") • Rod Length: 137.9 mm (5.429") • Rod/Stroke Ratio: 1.58 • Power: • Power: 170 hp (127 kW) @ 7600 rpm & 128 ft•lbf (173 N•m) @ 6200 rpm • Transmission: Y80 B18C2 • VTEC • Found in: o 1994-1999 Honda Integra VTi-R o AUDM Spec 1993-1999 Honda Integra VTi-R ? Displacement: 1797 cc ? Compression: 10.6:1 ? Power: 167 hp (125 kW) @ 7600 rpm ? Torque: 128 ft•lbf (175 N•m) @ 6200 rpm ? Redline: 8200 rpm ? Fuel Cut: 8300 rpm ? Transmission: Y80 (No LSD) 5-Speed Manual Transaxle ? 0/100km/h : <7.3 seconds B18C3 • VTEC • Found in: o 1995-1998 Acura Integra Type R • Power: 193 PS/189 hp (141 kW) @ 8200 rpm & 127 ft•lbf/172 N•m @ 7500 rpm B18C4 • VTEC • Found in: o 1996-2000 UK Civic 1.8i VTi 5-door Hatch o 1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon o 1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon o 1998-1999 EU Civic 1.8i VTi 5-door Hatch • Displacement: 1797 cc • Compression: 10.0:1 • Power: 169 hp (124 kW) @ 7600 rpm & 117 ft•lbf (158 N•m) @ 6200 rpm • Limit: 8200 rpm • Transmission: S9B w/ LSD. • 0/100km/h : 8.3 seconds (8.8 Aerodeck) B18C5 • VTEC • Found in: USDM DC2 Acura Integra Type-R (Integra Type-R) o 1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year) • Displacement: 1797 cc • Compression: 10.6:1 • Bore: 81 mm (3.189") • Stroke: 87.2 mm (3.433") • Rod Length: 137.9 mm (5.429") • Rod/Stroke Ratio: 1.58 • Power: 193 PS/189 hp (141 kW) @ 8200 rpm & 127 ft•lbf/172 N•m @ 7500 rpm • Transmission: S80 w/LSD B18C6 • VTEC • Found in: o 1998-2001 Honda Integra UK and Euro Spec Type R • Type: 1.8 litre 16v DOHC 4 cylinder in-line • Displacement: 1797 cc • Compression: 11.1:1 • Air intake diameter: 70 mm • Bore: 81 mm (3.189") • Stroke: 87.2 mm (3.433") • Rod Length: 137.9 mm (5.429") • Rod/Stroke Ratio: 1.58 • Power: 190 PS/139 kW/187 hp (SAE net hp) (139 kW) @ 7900 rpm & 131 ft•lbf/178 N•m @ 7300 rpm • Red-line: 8400 rpm • Transmission: S80 w/LSD B18C7 • VTEC • Found in: o 1996- Honda Integra Type R (Australia) • Power: 193 PS/189 hp (141 kW) @ 8200 rpm & 127 ft•lbf/172 N•m @ 7500 rpm B20A,B20A1 (16-Valve, 4 Cylinder, DOHC, PGM-FI) • "Honda" logo in center of valve cover - Filler cap on left side of cover. • Found in: o Serial numbers 1000001~, 1500001~ and 1550001~ ? 1985-1986 Honda Prelude Non-U.S. ? 1985-1986 Honda Accord Non-U.S. ? 1985-1986 Honda Vigor Non-U.S. o Serial numbers 1600001~ and 1640001~ ? 1987-1989 Honda Prelude jdm only -non u.s. b-20a5 ? 1987-1989 Honda Vigor Non-U.S. • Displacement: 1958 cc o bore: 81 mm (3.2 in) o stroke: 95 mm (3.7 in) • Compression: 9.4:1; 9.5:1 • Power: o (JDM, black top) 160 hp (119 kW) @ 6300 rpm & 186 nm @ 5000 rpm, using PH3 ECU o (EDM, gold top) 137 hp (102 kW) @ 6000 rpm & 172 nm @ 5000 rpm, using PJ5(602,603,752),PJ7,PH3 ECU w vac. advance • Transmission: B2K5, F2K5 B20A2 (16-Valve, 4 Cylinder, DOHC, PGM-FI) • Found in: o 1987-1989 Honda Accord Non-U.S. • Power: 142 hp (106 kW) @ 6200 rpm B20A3 (12-valve, SOHC, dual side-draft carburetors) • Found in: o 1988-1991 Honda Prelude 2.0 S • Power: 104 hp (78 kW) @ 5800 rpm (MT)With cata, 115 hp (86 kW) @ 5800 rpm without cata • Torque: 111 lb•ft (150 N•m) @ 4000 rpm • It was PGM-CARB microprocesor controlled (pk-1) B20A4 (12-Valve, SOHC, dual side-draft carburetors) • Found in: o 1988-1991 Honda Prelude Non-U.S. B20A5 (16-valve, DOHC, PGM-FI) • Found in: o 1988-1991 Honda Prelude 2.0Si • Power: 135 hp (101 kW) @ 6200 rpm • Torque: 127 lb•ft (172 N•m) @ 4000 rpm • Engine cc: 1958.14 • Cylinder cc: 489.535 • Deck cc: 13.885 • Head cc: 47.3 • Compression Ratio: 9.0:1 B20A6 (16-Valve, DOHC, PGM-FI) • Found in: o 1988-1991 Honda Prelude Non-U.S. New Zealand, and Australian Domestic Market 135 hp (101 kW)@6000 rpm 170 nm@5500 rpm KY model is one of them B20A7 (16-Valve, DOHC, PGM-FI) • Found in: o 1988-1991 Honda Prelude Non-U.S. UK, France, Holland, Norway, South Africa • Power 150 hp (112 kW)@6000 rpm o Torque 180 Nm@5500 rpm ? Compresion ratio 10.5:1 B20A8 (16-Valve, DOHC, PGM-FI) • Found in: o 1988-1991 Honda Prelude Non-U.S. Russian, Swedish Domestic Market o 1988-1989 Honda Accord Non-U.S. • Power 133 hp (99 kW) B20A9 (16-Valve, DOHC, PGM-FI) • Found in: o 1990-1991 Honda Prelude Non-U.S. Finland, German, Norway, Netherlands, Russia, Argentina • Power 140 hp (104 kW)@6000 rpm o Torque 175 Nm@4500 rpm ? Compresion ratio 10.5:1 B21A (16-valve, DOHC, PGM-FI) • Found in: o 1990-1991 Honda Prelude Si States • Very rare, it was only produced for the "Si States" models in Japan • Power: 145 hp (108 kW) • Torque: 186 N•m (137 lbf•ft) • Compression Ratio: 10.5:1[citation needed] engine using a pk-3 honda ECU B21A1 (16-valve, DOHC, PGM-FI) • Found in: o 1990-1991 Honda Prelude SI USDM o 1990-1991 Honda Prelude SR Canadian Market • Power: 140 hp (104 kW) @5800 rpm • Torque: 135 lb•ft (183 N•m) @5000 rpm • Engine cc: 2056.03 • Cylinder cc: 514.0075 • Deck cc: 10.191 • Head cc: 51.0 • Compression Ratio: 9.4:1 B20B • NON-VTEC • Found in: Honda CR-V, Honda Orthia • Displacement: 1973 • Power: 126 hp (94 kW)) @ 5400 rpm • Torque: 133 ft•lbf (180 N•m) @ 4300 rpm • Rod length: 137mm • Compression: 8.8:1 • Bore: 84 mm (3.3 in) • Stroke: 89 mm (3.5 in) • Redline: 6300 rpm red line B20Z • NON-VTEC • Found in: USDM 1999-2001 Honda CR-V • Displacement: 1973 • Power: 146 hp (109 kW) @ 6400 rpm • Torque: 133 ft•lbf (180 N•m) @ 4500 rpm • Compression: 9.6:1 • Bore: 84 mm (3.3 in) • Stroke: 89 mm (3.5 in) • Redline: 6900 rpm C20A The SOHC C20A is a 2.0 L version, producing 145 hp (108 kW). This was the first Honda V6 engine. Applications; non-North America: • 1985 Honda Legend The C20AT was a turbocharged version, producing 190 hp (140 kW). Applications; non-North America: • 1989 Honda Legend o ? NOTE: Honda made a "Wing-Turbo" Legend marketed under the Honda name and was only available in the Japanese Domestic Market. It was very rare and it had the turbocharged C20AT engine in it. The turbocharger used was a Variable Geometry turbo that Honda developed. The turbo used aerofoil style flappers all around the the turbine housing. These "Wings", as Honda called them, were controlled by vacuum and by the Legend's ECU and they were constantly adjusted. Basically, at low speeds the wings would be nearly closed to speed and direct exhaust pressure precisely on the turbine wheel. At cruise speeds, the wings would be open and it would act like a much larger turbo to increase fuel economy. This car was really quick and really powerful, but the price premium over the standard Legend was too much for most so the car disappeared. This was one of the only production Hondas ever turbocharged from the factory, along with the new Acura RDX and the older Honda City's. C25A The SOHC C25A is a 2.5 L version, producing 165 hp (123 kW). Applications; North America Only: • 1986-1987 Acura Legend Sedan, 151 hp (113 kW) • 1983-1985 Rover 825 Sedan, 151 hp (113 kW) UK and Europe (sold in US as STERLING) C27A The SOHC C27A is a 2.7 L version, producing 170 hp, (127 kW). Applications; North America Only: • SOHC non-VTEC o 1987 Acura Legend Coupe , 161 hp (120 kW) o 1988-1990 Acura Legend, 161 hp (120 kW) o 1995-1997 Honda Accord, 170 hp (128 kW) o 1985-1990 Rover 827/Sterling/Vitesse, 177 hp (non catalyst)UK and Europe (sold in US as STERLING Brand) o 1990-1996 Rover 827/Sterling/Coupe, 168 hp (catalyst) UK and Europe (sold in US as STERLING Brand until 1996) C30A The DOHC VTEC C30A is a 3.0 L version, producing 201 kW (270 bhp) and 285 N•m (210 ft•lbf) of torque. An advanced version of this engine exists (though not in a production form) that campaigned briefly in the 2004 Japanese SuperGT racing series (see All Japan Grand Touring Car Championship) by the factory-supported Team Honda Racing group in highly modified GT-spec NSXs. This engine has various upgrades and modifications by M-TEC (formerly Mugen) and is the first turbo-charged Honda engine used in the series (prior to 2003, the GT-spec NSXs used a highly advanced, naturally-aspirated variant of the C32B engine). Though the exact performance figures are kept secret, it's rumored to output more than 500 bhp. Applications: • 1991-1996 Honda NSX C32A The C32A is a 3.2 L version. The SOHC depending on model year, produces 200 and 230 hp (175 kW). Applications; North America Only: • C32A1 - SOHC USDM - 200 hp (150 kW) o 1991-1995 Acura Legend sedan o 1991-1992 Acura Legend coupe • C32A6 - SOHC USDM - 200 hp (150 kW) o 1996-1998 Acura 3.2TL • C32A5 - SOHC USDM - 230 hp (170 kW) at 206 ft•lbf (279 N•m) o 1994-1995 Acura Legend GS sedan o 1993-1995 Acura Legend LS coupe C32B There is also the C32B, a highly tuned DOHC version, used in the Honda NSX, which produces 290 hp (216 kW) and 224 lbf•ft (304 N•m). Applications: • 1997-2005 Honda NSX C35A The C35A is a SOHC and carries the largest displacement of the C series at 3.5L. Applications: • C35A - SOHC - 210–225 hp (155–170 kW) o 1996-2004 Acura 3.5RL (US/Canada) o 1996-2004 Honda Legend (non-US/Canada) |
Series D E
D13B1
• Found in: o 1988-1991 Honda Civic DX (European Market) ? Displacement : 1343 cm³ ? Bore and Stroke : 75 mm X 76 mm ? Compression : 9.5:1 ? Power, Torque : n/s (Not stated in Owners Manual) ? Valvetrain : SOHC, 4 valves per cylinder ? Fuel Control : Single Carburetor D13B2 • Found in: o 1992-1995 Honda Civic DX (European Market) ? Displacement : 1343 cm³ ? Bore and Stroke : 75 mm X 76 mm ? Compression : 9:1 ? Power, Torque : 75 hp (56 kW) @ 4500 rpm ? Valvetrain : SOHC, 4 valves per cylinder ? Fuel Control : Single Carburetor D14A1 • Found in: o 1987-1991 Honda Civic GL and 1990 CRX (European Market) ? Displacement : 1396 cm³ ? Bore and Stroke : 75 mm X 79 mm ? Compression : 9.3:1 ? Power, Torque : 90 hp (90 bhp) @ 6300 rpm, 112Nm @ 4500 rpm ? Valvetrain : SOHC, 16 valves ? Fuel Control : Dual Carburetor D14A2 • Found in: o 1995-1996 Honda Civic MA8 (European Market) ? Displacement : 1396 cm³ ? Bore and Stroke : 75.0 mm X 79.0 mm ? Compression : 9.2:1 ? Torque, Power : 117 Nm @ 3800 rpm, 66 kW @ 4800 rpm ? Valvetrain : SOHC, 4 valves per cylinder ? Fuel Control : Multi-point fuel Injection, PGM-FI D15A2 • Found in: o 1984-1987 Honda CRX DX o 1984-1987 Honda Civic (JDM) ? Displacement : 1488 cm³ ? Bore and Stroke : 74 mm X 86.5 mm ? Compression : 9.6:1 ? Power : 76 hp (57 kW) @ 4500 rpm & 84 ft•lbf @ 2500 rpm ? Valvetrain : SOHC 3 valves + 1 auxiliary valve for each cylinder ? Fuel Control : Carbureted, CVCC, CVCC was not equipped on Canadian CDM cars ? Known as the EW-2 from 84-86 D15A3 • Found in: o 1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ) ? Displacement : 1488 cm³ ? Bore and Stroke : 74 mm X 86.5 mm ? Compression : 8.7:1 ? Power : 91 hp (68 kW) @ 4800 rpm & 93 ft•lbf @ 3500 rpm ? Valvetrain : SOHC, 3 valves/cylinder ? Fuel Control : pgm-fi D15B • VTEC • Found in: o 1991-1999 Honda Civic VTi EG4 (Japanese Market) o 1992-1998 Honda CRX VXi EG1 (Japanese Market) ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Rod Length : 137 mm ? Compression : 9.3:1 ? Power : 128 hp (95 kW) @ 5800 rpm & 102 ft•lbf (14.1kg/m) @ 5200 rpm ? Redline : 7200 rpm ? Fuel Cut : 7411 rpm ? Valvetrain : SOHC VTEC ? Head Code : P08 ? Fuel Control : OBD-1 MPFI D15B (D15Z7) (with 3 stage VTEC) • 3-stage VTEC • Found in: o 1996-1999 Honda Civic VTi EK3 and Ferio Vi ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Rod Length : 137 mm ? Compression : 9.6:1 ? Power : 130 hp (97 kW) @ 7000 rpm & 102 ft•lbf (14.2kg/m) @ 5300 rpm ? Valvetrain : SOHC VTEC ? Fuel Control : OBD-2 MPFI D15B1 (Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake header) • Found in: o 1988-1991 Honda Civic Hatchback ? Displacement : 1493 cm³ ? Bore and stroke : 75 mm X 84.5 mm ? Compression : 9.2:1 ? Power : 70 hp (52 kW) @ 4500 rpm & 83 ft•lbf @ 3000 rpm ? Valvetrain : SOHC (4 valves per cylinder) ? Fuel Control : OBD-O DPFI D15B2 • Found in: o 1988-1991 Honda Civic GL/DX/DLX o 1988-1991 Honda CRX DX o 1992-1995 Honda Civic LSi Hatch/Saloon (European Market) o 1990-1995 Honda Concerto (European Market) ? Displacement : 1493 cm³ ? Bore and stroke : 75 mm X 84.5 mm ? Compression : 9.2:1 ? Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm ? Valvetrain : SOHC (4 valves per cylinder) ? Cam Gear : 38 tooth ? Fuel Control : PGM-FI Dual Point ? Redline : 7000 rpm D15B4 • Found in: o 1989-1991 Honda Civic GL (Australian Market) ? Displacement : 1493 cm³ ? Bore and stroke : 75 mm X 84.5 mm ? Compression : 9.2:1 ? Power : 90 hp (70 kW) @ 5200 rpm & 122 Nm @ 3800 rpm ? Valvetrain : SOHC (2-4 valves per cylinder, depending on year) ? Fuel Control : Dual Carburetor D15B6 • Found in: o 1988-1991 Honda CRX HFx ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Compression : 9.1:1 ? Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft•lbf @ 2800 rpm ? Valvetrain : SOHC (2 valves per cylinder) ? Fuel Control : OBD-0 MPFI D15B7 • Found in: o 1992-1995 Honda Civic CX (Canadian model) o 1992-1995 Honda Civic DX/LX o 1993-1995 Honda Civic del Sol S o 1992-1995 Honda Civic LSi Coupe (European Market) ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Compression : 9.2:1 ? Power : 102 hp (76 kW) @ 5600 rpm & 98 ft•lbf @ 3800 rpm ? Valvetrain : SOHC (4 valves per cylinder) ? Piston Code : PM3 ? Fuel Control : OBD-1 MPFI D15B8 • Found in: o 1992-1995 Honda Civic CX (U.S. model) ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Compression : 9.1:1 ? Power : 70 hp (52 kW) @ 4500 rpm & 83 ft•lbf @ 2800 rpm ? Valvetrain : SOHC (2 valves per cylinder) ? Fuel Control : OBD-1 MPFI D15Z1 • VTEC-E • Found in: o 1992-1995 Honda Civic VX o 1992-1995 Honda Civic VEi (European Market) ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Rod Length : 137 mm ? Compression : 9.3:1 ? Power : 92 hp (69 kW) @ 5600 rpm & 97 ft•lbf @ 4800 rpm ? Valvetrain : SOHC VTEC-E (4 valves per cylinder) ? Piston Code : P07 ? Fuel Control : OBD-1 MPFI D15Z4 • Found in: o 1996-2000 Civic Exi and SA Ballade & Civic 150i o Displacement : 1493 cm3 o Power : 90HP and 105HP(82Kw) @ 5800 rpm o Torque (ft•lbf@rpm): 99 (135 N•m) @ 4200 rpm o Valvetrain : SOHC non-VTEC 16v D15Z6 • VTEC • Found in: o 1996-2000 Honda Civic LSi (European Market) ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Rod Length : 137 mm ? Compression : 9.6:1 ? Power : 115hp @ 6500 rpm ? Torque : 100 ft•lbf (141 Nm) @ 4800 rpm ? VTEC Switchover : 2500 rpm ? Valvetrain : SOHC VTEC-E (4 valves per cylinder) ? Fuel Control : PGM-FI MPFI D15Z8 • VTEC-E • Found in: o 1996-2000 Honda Civic LS (European Market) ? Displacement : 1493 cm³ ? Bore and Stroke : 75 mm X 84.5 mm ? Compression : 9.1:1 ? Power : 84 kw (114 hp) @ 6500 rpm ? Torque : 134 Nm (95 ft•lbf) @ 5500 rpm D16A1 • Found in: o 1986-89 Acura Integra (USA) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? 1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1 ? 1986-1987 Power : 113 hp (84 kW) @ 6250rpm Torque : 99 ft•lbf @ 5500rpm ? 1988-1989 Power : 118 hp (88 kW) @ 6250rpm Torque: 103 ft•lbf @ 5500rpm ? Valvetrain : DOHC non-VTEC ? Piston Code 1986-87 : PG6 ? Piston Code 1988-89 : P29 (PM7 is ZC equivalent/same piston) ? Fuel Control : OBD-0 MPFI D16A3 • Found in: o 1986-89 Acura Integra (Australia) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.5:1 ? Power : 118 hp (88 kW) @ 5600 rpm & 103 ft•lbf @ 4800 rpm ? Valvetrain : DOHC ? Fuel Control : OBD-0 MPFI D16A6 • Found in: o 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD o 1990-1991 Honda Civic EX Sedan o 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ) o 1989-1996 Rover 216/416 GSi (UK/Europe) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.1:1 ? Power : 115 hp (86 kW) @ 5600 rpm & 95 ft•lbf @ 3,800 rpm, redline 6500 rpm (USA) ? Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108 ? Valvetrain : SOHC ? Fuel Control : OBD-0 four-point PGM-FI ? Head Code : PM3 ? Piston Code : PM6 D16A7 Basically a D16A6 that came without a catalytic converter, like the European version of the D16A6.ex US 4 Door • Found in: o 88-95 Models in South Africa o Ballade SH4 and SR4 ( D16A7 / EE4 ) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.6:1 ? Power : 115hp @ 5900 rpm & 100ft•lbf @ 4800 rpm ? Valvetrain : SOHC ? Fuel Control : OBD-0 Multi-point PGM-FI D16A8 • Found in: o 1988-1995 Civic/CRX/Concerto (UK/Europe/Australia) o 1990-1995 Rover 216/416 GTi(UK/Europe) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.5:1 ? Power : 125 hp (93 kW) @ 6800 rpm & 108 ft•lbf @ 5900 rpm ? Valvetrain : DOHC ? Fuel Control : OBD-0 MPFI ? ECU Code: PM7 D16A9 (Same as D16A8 but without a catalytic converter) • Found in: o 1988-1991 Civic/Concerto (UK/Europe) o 1988-1991 CRX (UK/Europe/South Africa) o 1989-1996 Rover 216/416 GTi (UK/Europe) o 1992-1995 Civic Si (Peruvian version) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.5:1 ? Power : 130 hp (97 kW) @ 6800 rpm & 108 ft•lbf @ 5900 rpm ? Valvetrain : DOHC ? Fuel Control : OBD-0 MPFI ? ECU Code: PM7 ? GearBox : L3 Cable type D16Y3 • Found in: o 1995-1997 Honda Civic MB1 LS (UK/Europe) ? Displacement : 1590 cm³ ? Power : 115 hp (86 kW) @ 5600 rpm, redline 6500 rpm ? Valvetrain : SOHC D16Y5 • VTEC-E • Found in: o 1996-2000 Honda Civic HX o 1996 Honda Civic EX(sedan Peruvian version) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.4:1 ? Power : 115 hp (86 kW)@ 5600 rpm & 100 ft•lbf @ 4500 rpm ? Valvetrain : SOHC VTEC-E ? Fuel Control : OBD-2 MPFI ? Head Code : P2J o 1996-2000 VTi (Phils. & NZ) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : ? Power : 127 hp (95 kW)@ 5800rpm ? Valvetrain : SOHC VTEC-E ? Fuel Control : OBD-2 MPFI ? Head Code : P2J ? ECU Code : P2M ? Piston Code : P2MY D16Y7 NON VTEC • Found in: o 1996-2000 Honda Civic DX/VP/LX/CX o 1999 Honda Civic Special Edition - SE(Canada) o 1996-97 Honda del Sol S ? Displacement : 1593 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.4:1 ? Power : 106hp @ 6400 rpm ? Torque (ft•lbf@rpm): 103 @ 4,600 rpm ? Valvetrain : SOHC 16 valves ? Fuel Control : OBD2 MPFI ? Head Code : P2F ? Piston Code : P2E D16Y8 Also available in New Zealand under the code D16Y6 Australian version D16Y4 • Found in o 1997-1998 Honda Civic EX Sedan o 1996-1998 Honda Civic EX Coupe o 1996-2000 Honda Civic EK Sedan o 1996-2000 Honda Civic EX (USDM) o 1996-2000 Honda Civic SI (Canada Only) o 1996-2000 Acura 1.6EL (Canada Only) o 1996-1997 Honda del Sol Si ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.6:1 ? D16Y8 1.6 16V SOHC VTEC 2 PGM-FI 1590 ? 127 hp@5600 rpm 108tq@4500 rpm ? Head Code : P2J ? Piston Code : P2P ? Redline 7000 rpm D16Y9 • Found in: o 1996-2000 Honda Ballade and Civic in South Africa ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.2:1 ? Power, Torque : {{Auto hp120 / 89kw} @ 5900 rpm 146nM @ 4000 rpm ? Valvetrain : SOHC, 4 valves per cylinder non - VTEC ? Fuel Control : Fuel Injection D16Z5 (Basically the same engine as the D16A9, but now with a catalytic converter and lamda sensor) • Found in: o 1988-1992 Honda CRX (European Market) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.5:1 ? Power : 124 hp (92 kW) @ 6800 rpm ? Valvetrain : DOHC ? Cam Gear : 34 tooth ? Fuel Control : OBD-0 PGM-FI ? Head Code : P7 ? Piston Code : PM7 ? ECU Code: PM7 D16Z6 • Found in o 1992-1995 Honda Civic (ex/si) o 1993-1995 Honda Del Sol Si (only USDM) ? Displacement : 1590 cm³ ? Bore and Stroke : 75 mm X 90 mm ? Compression : 9.2:1 ? Power : 125 hp (93 kW) @ 6600 rpm & 106 ft•lbf @ 5200 rpm ? Redline : 7200 rpm ? Fuel Cut : 7411 rpm ? Valvetrain : SOHC VTEC ? Fuel Control : OBD-1 MPFI ? Head Code : P08 ? ECU Code : P28 D16Z9 • Found in: o 1995-1997 Civic 1.6i British Market ? o Power : 126 hp (94 kW) ? Valvetrain : SOHC VTEC D17A1 • Found in: o 2001-2005 Honda Civic DX/LX/VP ? Displacement : 1668 cm³ ? Bore and Stroke : 75 mm X 94.4 mm ? Compression : 9.5:1 ? Power : 115 hp (86 kW) @ 5600 rpm & 110 ft•lbf @ 4500 rpm ? Valvetrain : SOHC ? Fuel Control : OBD-2 MPFI D17A2 • VTEC-E • Found in: o 2001-2005 Honda Civic EX o 2001-2005 Honda Civic Si (Canada only) ? Displacement : 1668 cm³ ? Bore and Stroke : 74.98 mm X 94.4 mm ? Compression : 9.9:1 ? Power : 127 hp @ 5800 rpm & 114 ft•lbf @ 4800 rpm ? Valvetrain : SOHC VTEC-E ? Fuel Control : OBD-2 MPFI D17A6 • VTEC-E • Found in: o 2001-2005 Honda Civic HX ? Displacement : 1668 cm³ ? Bore and Stroke : 75 mm X 94.4 mm ? Compression : 9.5:1 ? Power : 125 hp (93 kW) @ 5800 rpm & 111 ft•lbf @ 3800 rpm ? Valvetrain : SOHC VTEC-Ec ? Fuel Control : OBD-2 MPFI D17A7 • Found in: o 2004-2005 Honda Civic GX o Uses CNG (Compressed Natural Gas) ? Displacement : 1668 cm³ ? Bore and Stroke : 75 mm X 94.4 mm ? Compression : 12.5:1 ? Power : 115 @ 5800 rpm & 98 ft•lbf @ 3800 rpm ? Valvetrain : SOHC ? Fuel Control : OBD-2 MPFI EB The EB series displaced 1.2 L (1170 cc) and was an SOHC 8-valve design with a 2 barrel carburetor. Output for the EB1 was 50 bhp (37 kW) @ 5000 rpm and 59 ft•lbf (80 N m) @ 3000 rpm, and this was up to 63 bhp (47 kW) @ 5000 rpm and 77 ft•lbf (104 N m) @ 3000 rpm for the EB2 and EB3. • EB1 o 1973- Honda Civic • EB2 o 1974-1979 Honda Civic • EB3 o 1978-1979 Honda Civic EC The EC series engine is used in the Gasoline / Electric Honda Insight Hybrid. This 3 Cylinder Engine is a Sohc 12 Valve sized 1.0L (995 cc)-DK. The ECA1 produces 68 hp (50 kW) @ 5700 rpm and 67 ft•lbf (N m) of Torque @ 4800. The ECA1 motor is assisted in various circumstances by a 10 kW Permanent Magnet DC Electric Motor adding 8 Horsepower / 16 ft•lbf Torque throughout the Entire RPM Range. It is completely unrelated to the rest of the E-series engines. • ECA1 o 2000-2006 Honda Insight ED The ED series introduced the CVCC technology. This group displaced 1.5 L (1487 cc) and used an SOHC 8-valve design. Output with a 3 barrel carburetor was 52 hp (39 kW) @ 5000 rpm and 68 ft•lbf (92 N m) @ 3000 rpm. • ED1 o 1975- Honda Civic CVCC • ED2 o 1975- Honda Civic Wagon • ED3 o 1976-1979 Honda Civic CVCC • ED4 o 1976-1979 Honda Civic Wagon EL The EL displaced 1.6 L (1600 cc) and was an SOHC 8-valve engine with a 3 barrel carburetor. Output was 68 hp (51 kW) @ 5000 rpm and 85 ft•lbf (115 N m) @ 3000 rpm. • EL1 o 1976-1978 Honda Accord EJ The EJ displaced 1.3 L (1335 cc) and was an SOHC 8-valve engine with a 3 barrel carburetor. Output was 68 hp (51 kW) @ 5000 rpm and 77 ft•lbf (104 N m) @ 3000 rpm. • EJ1 o 1980- Honda Civic o 1981-1983 Honda Civic EK There were two different EK engines, until 1981 the heads used a 2 port exhaust design. After 1981 the head used a 4 port exhaust design. Both had a 12 valve head, 8 main valves and 4 CVCC, or auxiliary valves. Both displaced 1.8 L (1751 cc). 2-port output was 72 hp (54 kW) @ 4500 rpm and 94 ft•lbf (127 N m) @ 3000 rpm, while the 4 port head raised this to 75 hp (56 kW) @ 4500 rpm and 96 ft•lbf (130 N m) @ 3000 rpm. • EK1 2 port o 1979-1981 Honda Accord o 1979-1981 Honda Prelude • EK1 4 port o 1982-1983 Honda Accord o 1982 Honda Prelude EM The EM displaced 1.5 L (1487 cc) and was an SOHC 12-valve CVCC engine. Early versions produced 52 hp (39 kW) @ 5000 rpm and 68 ft•lbf (92 Nm) @ 3000 rpm, while later ones upped the output to 63 hp (47 kW) @ 5000 rpm and 77 ft•lbf (104 N m) @ 3000 rpm. All used a 3 barrel carburetor. • EM1 o 1980 Honda Civic, 52 hp (39 kW) o 1981-1983 Honda Civic, 63 hp (47 kW) ES The ES displaced 1.8 L (1829 cc). All ES engines were SOHC 12-valve engines. The ES1 used dual sidedraft carburetors to produce 100 hp (75 kW) @ 5500 rpm and 104 ft•lbf (141 N m) @ 4000 rpm. The ES2 replaced this with a standard 3 barrel carburetor for 86 hp (64 kW) @ 5800 rpm and 99 ft•lbf (134 N m) @ 3500 rpm. Finally, the ES3 used PGM-FI for 101 hp (75 kW) @ 5800 rpm and 108 ft•lbf (146 N m) @ 2500 rpm. • ES1 o 1983-1984 Honda Prelude • ES2 o 1984-1985 Honda Accord • ES3 o 1985- Honda Accord SE-i ET The ET displaced 1.8 L (1829 cc) and was an SOHC 12-valve engine. Dual sidedraft carburetors produced 100 hp (75 kW) @ 5500 rpm and 104 ft•lbf (141 N m) @ 4000 rpm. • ET1 o 1985-1986 Honda Prelude EV The EV displaced 1.3 L (1342 cc) and was an SOHC 12-valve design. 3 barrel carburetors produced 60 hp (45 kW) @ 5500 rpm and 73 ft•lbf (99 N m) @ 3500 rpm. • EV1 o 1984-1986 Honda Civic o 1984-1986 Honda CRX • EV2 o 1984-1989 Rover 213 EW The final E-family engine was the EW. Displacing 1.5 L (1488 cc), the EWs were SOHC 12-valve engines. Early 3 barrel EW1s produced between 58 and 76 hp (43 and 57 kW) and 80 to 84 ft•lbf (108 to 114 N m). The fuel injected EW3 and EW4 produced 91 hp (68 kW) @ 5500 rpm and 93 ft•lbf (126 N m) @ 4500 rpm. • EW1 o 1984-1985 Honda Civic/CRX DX(unlabeled) o 1984-1987 Honda Civic • EW2 o 1984-1987 Honda Civic non-CVCC EFI (CDM) • EW3 o 1985- Honda Civic/CRX Si • EW4 o 1985-1987 Honda CRX Si o 1986-1987 Honda Civic Si |
Series F J K
SOHC engines
F18A This engine was used by Honda. • Bore × Stroke: 85.0 × 81.0 mm • Displacement: 1849 cc • Valve Configuration: SOHC, 16 valves • 118 bhp up to 1997 • 105PS @ 6000 rpm, 14.6 kg m @ 4000 rpm (PGM-carb) • Fuel consumption : 13.0 km/l F18B This engine was used for the Honda Accord 1.8 VTS in Japan. Specifications • Bore × Stroke: 85.0 × 81.0 mm • Displacement: 1849 cc • Valve Configuration: SOHC, 16 valves, VTEC • Compression ratio: 9.3:1 • Max power: 138PS (103 kW) • Max torque: 124 ft•lbf (165 N m) F20A This engine series was used in the Honda Accords in Japan and Europe. The DOHC F20A was also derived from this engine (see below). Specifications • Bore × Stroke: 85.0 × 88.0 mm • Displacement: 1997 cc • Valve Configuration: SOHC, 16 valves • Max output : F20A2 and F20A4 136 PS @ 5400 rpm (PGM-Fi), 110 PS @ 6000 rpm (PGM-carb) • Max output : F20A7 147 PS @ 5600 rpm (PGM-Fi) • Max torque : F20A2 and F20A4 18.5 kg m @ 4300 rpm (PGM-Fi), 16.1 kg m @ 3800 rpm (PGM-carb) • Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-Fi) • Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb) This engine also spawned many variants, according to market, but the specs remain largely similar F20B This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. Also had a DOHC derivative (see below) Specifications • Bore × Stroke: 85.0 × 88.0 mm • Displacement: 1997 cc • Configuration Valve: SOHC, 16 valves, VTEC • Compression ratio: 11.0:1 • Max power: 148 PS (109 kW) @ 6000 rpm (4WD), 150 PS (110 kW) @ 6000 rpm • Max torque: 183 N m @ 5000 rpm (4WD), 186 N m @ 5000 rpm F20Z This engine series is similar to the F20A above, used in the Honda Accord in Asia and Europe. Specifications • Bore × Stroke: 85.0 × 88.0 mm • Displacement: 1997 cc • Valve Configuration: SOHC, 16 valves F22A This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar. Specifications • Bore × Stroke: 85.0 × 95.0 mm • Displacement: 2156 cc • Valve Configuration: SOHC, 16 valves, Non vtec • Compression ratio: 8.8:1 • Max power: o F22A1: 125 hp (93 kW) @ 5200 rpm o F22A4: 130 hp (97 kW) @ 5200 rpm o F22A6: 140 hp (104 kW) @ 5600 rpm o F22A7: 150 hp (110 kW) @ 5900 rpm (147hp/108kW with automatic transmission) • Max torque: o F22A1: 137 ft•lbf (186 N m) @ 4000 rpm o F22A4: 142 ft•lbf (193 N m) @ 4000 rpm o F22A6: 142 ft•lbf (193 N m) @ 4500 rpm o F22A7: 145 ft•lbf (198 N m) @ 5000 rpm F22B1 This engine was used in the Honda Accord EX and Acura CL 2.2. It was the first F engine to feature VTEC. Specifications • Bore × Stroke: 85.0 × 95.0 mm • Displacement: 2156 cc • Valve Configuration: SOHC, 16 valves, VTEC • Compression ratio: 8.8:1 • Max power: 145 hp (108 kW) @ 5500 rpm • Max torque: 147 ft•lbf (199 N m) @ 4500 rpm F22B2 This engine was used in the 1994-1997 Honda Accord DX, LX and SE. The F22B6 in the 1995-1997 Honda Odyssey and the F22B8 in the Honda Shuttle are substantially similar. Specifications • Bore × Stroke: 85.0 × 95.0 mm • Displacement: 2156 cc • Valve Configuration: SOHC, 16 valves • Compression ratio: 8.8:1 • Max power: 130 hp (97 kW) @ 5300 rpm • Max torque: 139 ft•lbf (188 N m) @ 4200 rpm The F22B in the BA9 Prelude had a DOHC configuration JDM engines were stamped only as F22B. F22Z2 This engine was used in the Honda Accord 2.2i. Specifications • Bore × Stroke: 85.0 × 95.0 mm • Displacement: 2156 cc • Valve Configuration: SOHC, 16 valves, VTEC • Compression ratio: 9.3:1 • Max power: 150 hp (112 kW) @ 5500 rpm • Max torque: 148 ft•lbf (200 Nm) @ 4500 rpm F23A1 This engine was used in the Honda Accord EX, SE, and LX, and Acura 2.3CL in North America. Specifications • Bore × Stroke: 86.0 × 97.0 mm • Displacement: 2254 cc • Valve Configuration: SOHC, 16 valves, VTEC • Compression ratio: 9.3:1 • Max power: 150 hp (112 kW) @ 5700 rpm • Max torque: 152 ft•lbf (205 N m) @ 4900 rpm The F23A4 is substantially similar, but features ULEV certification with a slight reduction of horsepower: 148 hp (110 kW) with a maximum torque of 148 ft•lbf (200 Nm). The 1998 Honda Odyssey and the 1998-1999 Isuzu Oasis used the F23A7 engine, which was substantially similar to the F23A1. F23A5 This engine was used in the 1998-2002 Honda Accord DX in North America. Specifications • Bore × Stroke: 86.0 × 97.0 mm • Displacement: 2254 cc • Valve Configuration: SOHC, 16 valves • Compression ratio: 8.8:1 • Max power: 135 hp (100 kW) @ 5500 rpm • Max torque: 153 ft•lbf (206 Nm) @ 4500 rpm DOHC engines F20A This engine was used in the 1990-1993 Honda Accord 2.0Si in Japan. Specifications • Bore × Stroke: 85.0 × 88.0 mm • Displacement: 1997 cc • Valve Configuration: DOHC, 16 valves • Compression ratio: 9.5:1 • Max power: 150 hp (112 kW) @ 6100 rpm • Max torque: 137 ft•lbf (186 Nm) @ 5000 rpm F20B This engine was used in the 1998-2002 Honda Accord SiR and SiR-T (manual) in non-US countries. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version, as it was tuned for more mid-range torque than its manual transmission counterpart. Specifications • Bore × Stroke: 85.0 × 88.0 mm • Displacement: 1997 cc • Valve Configuration: DOHC, 16 valves, VTEC • Compression ratio: 11.0:1 • Max power: 180PS (auto)-200PS (manual) (134-149 kW) @ 7000 rpm • Max torque: 141-144 ft•lbf (189 N m) @ 5500 rpm F20C Main article: Honda F20C engine This engine was a radical departure from previous F engines, and only shared basic dimensions such as bore spacing. It was designed specifically for the Honda S2000 and shares some engineering with the Honda K engine. A long-stroke F22C1 variant was also produced. F22B This engine was used in the 1992-1996 Honda Prelude Si in Japan. It is similar to the H23A,. Specifications • Bore × Stroke: 85.0 × 95.0 mm • Displacement: 2156 cc • Valve Configuration: DOHC, 16 valves • Compression ratio: 9.3:1 • Max power: 160 hp (119 kW) @ 6000 rpm • Max torque: 148 ft•lbf (200 N m) @ 5000 rpm The Honda G series engine is an inline 5 cylinder gasoline engine, originally used in the 1992 Acura Vigor and Honda Accord. In 1996, the Acura 2.5 TL was made available with the 2.5 L 176 hp (131 kW) SOHC 20-valve 5-cylinder engine from the Vigor. In 1999 the 2.5L engine was dropped from the TL line-up. Specifications • Type: In-line 5 cylinder, aluminum block and head • Valve Configuration: SOHC, with 4 valves per cylinder G20A1 • Displacement: 1990 cc G25A1 • Displacement: 2451 cc • Bore: 85.0 mm (3.35 in) • Stroke: 86.40 mm (3.402 in) • Compression ratio: 9.0:1 • Max Power: 176 hp (131 kW) @ 6300 rpm • Max Torque: 170 ft•lbf (230 N•m) @3900 • Redline: 6800 rpm • Fuel Cutoff: 7100 rpm H22A The H22A debuted in 1993 for use in the Honda Prelude VTEC as the H22A1. Versions of the H22A would be the Prelude's signature high-performance engine worldwide until the end of Prelude production in 2001. It was also used in the 1994–1997 Honda Accord SiR and 1998–2003 Honda Accord Euro-R in Japan and Accord Type-R in the UK and Europe(however different cams and a different intake manifold were used in the Euro R H22A). The H22A in the Prelude Type-S, CH6 Type-R and CL1 Euro-R came with the trademark red crinkle finish valve cover. Specifications • Bore × Stroke: 87.0 × 90.70 mm (3.571 in) • Displacement: 2157 cc (132 cu. in.) • Valve Configuration: DOHC, 16 valves, VTEC • Type: In-line 4 cylinder, aluminum block and head • Compression ratio: 10.0:1 (North America); 10.6–11.0:1 (Japan) • Max power: 190 PS (187 hp/140 kW)/187hp (CD6 Accord); 200 PS (BB1/4/6 Prelude SiR's); 220 PS (Euro-R & Prelude Type-S) ;A7 220 bhp DIN (Type-R)(142–164 kW) • Max torque: 156–167 ft•lbf (207–217 Nm) • Redline: 7600 rpm • Rev Cut: 7800 rpm • Engine Control System: Honda Systems PGM-FI with port fuel injection • Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift H22A4 • The H22A4 is the designation of the engine used in the Base and Type-SH 97-01 Honda Prelude. This engine was only released in the US in all their models, and these are designated with the "black tops". H22A8 • This motor was only released within the European versions of the Prelude and can be designated with the "red tops". H23A1 The H23A1 was an increased-stroke, non-VTEC version of the H22a, designed for the North American market version of the 1992–1996 Honda Prelude Si. It shared the same Fiber Reinforced Metal (FRM) cylinder wall liners with the H22a. Specifications • Bore x Stroke: 87.0 x 95.0 mm (3.74 in) • Displacement: 2258 cc (138 cu. in.) • Valve Configuration: DOHC, 16 valves • Type: In-line 4 cylinder, aluminum block and head • Compression ratio: 9.8:1 • Max power: 160 hp (119 kW) • Max torque: 163ft•lbf (207 Nm) • Redline: 6500 rpm • Engine Control System: Honda Systems PGM-FI with port fuel injection • Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder There is also a DOHC VTEC version of the H23A, available in the CH6 and CL2(4WD) accord (CF4 wagon) SiR in the European Markets. Specs remain largely similar to the H23A for North America, albeit differ in the introduction of VTEC mechanism and more power Specifications • Compression ratio: 10.6:1 • Max output : 200 PS (197 hp/147 kW) @ 6800 rpm • Max torque : 220 N•m (160 ft•lbf) @ 5300 rpm • Redline: 7200 rpm J25 The J25A was the first J-series engine produced. It was only used in the export-model Inspire/Saber models, however. The J25A displaced 2.5 L and was an SOHC VTEC design. Output was 192 hp (143 kW). • J25A o 1999 Honda Inspire o 1999 Honda Saber J30 The J30 displaces 3.0 L and is a SOHC VTEC design. Output for the J30A1 was 200 hp (149 kW) and 195 ft•lbf (264 N•m) of torque. The J30A4 pushed output to 240 hp (179 kW) and 212 ft•lbf (287 N•m) using a three-way VTEC system, higher (10:1) compression ratio, and a novel exhaust manifold cast as one piece with the cylinder head. This version was on the Ward's 10 Best Engines list for 2003 and 2004. The IMA hybrid version was on the list for 2005. In 2006 to mark the 30th anniversary of the Accord, Honda created the J30A5, which boosted output to 244 hp (SAE Net 08/04) and 211 ft•lbf (SAE Net 08/04) of torque. According to Honda, horsepower gains were achieved with extensive improvements to the airflow of the intake and exhaust systems. The J30A1 used in the 6th-generation Accord (1998-2002) has heads which are very similar to the J32* engines used in Acura CL and TL Type-S engines of approximately the same years. This makes it possible to swap in J32A2 camshafts. These are readily available and not particularly expensive (about $200 for two camshafts plus $40 or so for gaskets and other items, vs. $1000+ for custom-ground camshafts from other sources) and produce excellent performance gains, particularly in the mid to high RPM range. However, the stock J30A1 valve springs are not as stiff as the J32A2 valve springs, so the valves may need adjustment more frequently than on an unmodified J30A1 engine. Also, 1998-1999 Accords used a distributor, which means the rear camshaft has to be notched by a machinist in order to work in those cars. (2000 and above J30A1s use direct ignition and thus can be dropped in unmodified.) • J30A1 o 1997-1999 Acura 3.0CL o 1998-2002 Honda Accord V6 o 2000-2004 Honda Odyssey • J30A4 o 2003-2005 Honda Accord V6 • J30A5 o 2006-2007 Honda Accord V6 • Variable Cylinder Management o 2005 Honda Accord Hybrid J32 The J32 displaces 3.2 L and is a SOHC VTEC design. Bore is 89 mm (3.5 in) and stroke is 86 mm (3.4 in). Output was 225 hp (168 kW) for the J32A1, with the J32A2 raising output to 260 hp (194 kW). The J32A3's output in the 2004/2005 TL is 270 hp (201 kW). SAE corrected hp for the 2006 TL is 258 hp (192 kW). • J32A1 o 1999-2003 Acura TL o 2001-2003 Acura CL • J32A2 o 2001-2003 Acura CL Type-S o 2002-2003 Acura TL Type-S • J32A3 o 2004+ Acura TL J35 The J35 displaced 3.5 L (3471 cc) and is an SOHC VTEC design. Bore is 89 mm (3.5 in) and stroke is 93 mm (3.7 in). Output was 210 hp (157 kW) for the J35A1, 265 hp (198 kW) and 253 ft•lbf (343 N•m) for the J35A3, and 240 hp (178.97 kW) @ 5500 rpm and 242 ft•lbf (327.74 Nm) @ 4500 rpm for the J35A4. The new J35 used in the Acura RL produces 290 hp (224 kW) at 6200 rpm and 256 ft•lbf (347 N•m) at 5000 rpm. This engine was on the Ward's 10 Best Engines list for 2005. The J35A91 used in the Honda Ridgeline produces 247 hp (184 kW) at 5750 rpm and 245 ft•lbf (332 N•m) at 4500 rpm. The J35 was also used by General Motors in the 2004-2007 Saturn VUE, though GM refers to it as the L66. • J35A1 o 1999-2001 Honda Odyssey • J35A3 o Acura MDX o 2005-2008 Acura RL o 2007+ Acura TL Type-S • J35A4 o 2002-2004 Honda Odyssey • J35A9 o Honda Ridgeline o Honda Pilot (VTM-4 models) • J35Z1 - Variable Cylinder Management o 2005 Honda Odyssey o 2006 Honda Pilot (front-wheel-drive models) • J35Z2 - Variable Cylinder Management o 2008 Honda Accord (except V6 6MT coupe) J37 The latest variant J37A1 displaces 3664 cc with bore 90 mm (3.5 in) and stroke of 96 mm (3.8 in). Compression ratio is 11:1. Rated output is 300 hp (220 kW) at 6000 rpm and 275 lb•ft (373 N•m) at 5000 rpm. The J37 is used in the 2007+ Acura MDX and 2009 Acura RL K20A Bore is 86 mm & Stroke is 86 mm for all of the K20 engines. • Found in: o 2007- Honda Civic Type-R (FD2) ? Displacement: 1998 cc ? Compression: 11.7:1 ? Power: 222 bhp (225 PS, 165 kW) @ 8000 rpm ? Torque: 159 ft•lbf (215 N•m) @ 6100 rpm ? Redline: 8400 rpm o 2001-2005 Honda Civic Type-R (EP3) ? Displacement: 1998 cc ? Compression: 11.5:1 ? Power: 212 bhp (215 PS, 158 kW) @ 8000 rpm ? Torque: 149 ft•lbf (202 N•m) @ 7000 rpm ? Redline: 8400 rpm o 2001-2007 Honda Integra Type-R (DC5) ? Displacement: 1998 cc ? Compression: 11.5:1 ? Power: 217 bhp (220 PS, 162 kW) @ 8000 rpm ? Torque: 152 ft•lbf (206 N•m) @ 7000 rpm ? Redline: 8500 rpm ? VTEC Engagement: 5600rpm o 2003-2007 Honda Accord Euro-R ? Displacement: 1998 cc ? Compression: 11.5:1 ? Power: 217 bhp (220 PS, 162 kW) @ 8000 rpm ? Torque: 152 ft•lbf (206 N•m) @ 7000 rpm ? Redline: 8500 rpm K20A2 • Found in: o 2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP3, European) ? Displacement: 1998 cc ? Compression: 11.0:1 ? Power: 200ps/197hp (147kW) @ 7400rpm ? Torque: 142ft•lbf (193N•m) @ 6000rpm ? Redline: 7800rpm ? VTEC Engagement: 5800rpm K20A3 • Found in: o 2002-2005 Honda Civic Si ? Displacement: 1998 cc ? Compression: 9.8:1 ? Power: 160 hp (119 kW)* (119 kW) @ 6500 rpm ? Torque: 139 @ 5000 rpm o 2002-2006 Acura RSX ? Displacement: 1998 cc ? Compression: 9.8:1 ? Power: 155 hp (116 kW)* (115 kW) @ 6500 rpm ? Torque: 139 lb•ft (188 N•m)* (191 N•m) @ 4000 rpm ? Redline: 6800 rpm ? (* Horsepower and torque calculations reflect new SAE J1349 procedures revised August 2004) • (The intake manifold is often credited with being responsible for the difference in HP between these two variants. The Civic Si being equipped with an aluminium intake manifold, and the RSX Base model equipped with a plastic version). (The base rsx makes 10 more lbs of torque then the Civic Si due to the fact of the "plastic" intake manifold and it is a dual runner) K20Z1 • Found in: o 2005-2006 Acura RSX-S ? Displacement: 1998 cc ? Compression: 11.0:1 ? Power: 201 hp (154 kW) @ 7800 rpm (SAE net J1349 Rev 8/04) ? Torque: 141 ft•lbf (194 N•m) @ 7000 rpm (SAE net J1349 Rev 8/04) ? Redline: 8100 rpm K20Z2 • Found in: o 2006- Acura CSX (Canada) ? Displacement: 1998 cc ? Compression: 9.6:1 ? Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04) ? Torque: 139 ft•lbf (188 N•m) @ 4500 rpm / 188 N•m @ 4200 rpm (Singapore) ? Redline: 6800 rpm o 2006- Honda Civic (JDM) ? Displacement: 1998 cc ? Compression: 9.6:1 ? Power: 155 hp (114 kW) @ 6000 rpm ? Torque: 139 ft•lbf (188 N•m) @ 4500 rpm ? Redline: 6800 rpm o 2006- Honda Accord Sport(Europe) ? Displacement: 1998 cc ? Compression: 9.6:1 ? Power: 155 hp (114 kW) @ 6000 rpm ? Torque: 139 ft•lbf (188 N•m) @ 4500 rpm ? Redline: 6800 rpm K20Z3 This inline-4 cylinder internal combustion engine is found in the US market Honda Civic Si (2006+) & Canadian market Acura CSX Type-S. It has an aluminium block with an aluminium head, and a bore and stroke of 86 mm*86 mm, resulting in a 2.0 Liter displacement. • Found in: o 2006+ Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007 Acura CSX Type-S ? Displacement : 1998 cc ? Compression : 11.3:1 ? Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04) ? Torque: 139 ft•lbf (189 N•m) @ 6200 rpm (sae NET Rev 8/04) ? Redline: 8300 rpm K20Z4 This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Type-R (FN2). It has an aluminium block with an aluminium head, and a bore and stroke of 86 mm*86 mm, resulting in a 2.0 Liter displacement. • Found in: o 2007 Honda Civic Type-R (FN2) (Europe Market) ? Displacement : 1998 cc ? Compression : 11.0:1 ? Power: 198 bhp (201 PS, 148 kW) @ 7800 rpm ? Torque: 142 ft•lbf (193 N•m) @ 5600 rpm ? Redline: 8200 rpm K23A1 • Turbocharged • Found in: o 2007/2008 Acura RDX ? Displacement: 2300 cc (acura.com) ? Compression: 8.8:1 (acura.com) ? Power: 240 hp (179 kW) @ 6000 rpm (SAE net) ? Torque: 260 lb•ft (353 N•m) @ 4500 rpm (SAE net) ? Redline: 6800 rpm (acura.com) ? Bore: 86 mm ? Stroke: 99 mm K24A1 • Found in: o 2002-2006 Honda CR-V ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 9.6:1 ? Power: 156 hp (119 kW) @ 6000 rpm ? Torque: 162 ft•lbf (220 N•m) @ 3600 rpm ? Redline: 6500 rpm K24A2 • Found in: o 2004-2008 Acura TSX ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 10.5:1 ? Power: 212 hp (147 kW) @ 6800 rpm (2004-2005) ? Power: 222 hp (150 kW) @ 6800 rpm (2006-2007) *SAE Net Rev 8/04 ? Torque: 166 ft•lbf (225 N•m) @ 4500 rpm (2004-2005) ? Torque: 164 ft•lbf (222 N•m) @ 4500 rpm (2006-2007)*SAE Net Rev 8/04 ? VTEC Engagement: 6000 RPM ? Redline: 7100 rpm K24A3 • Found in: o 2003-2007 Honda Accord (Europe and Japan) and 2003-2007 Honda Accord Euro CL9 (Australia) ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 10.5:1 ? Power: 189 hp (140 kW) @ 6800 rpm ? Torque: 164.5 ft•lbf (223 N•m) @ 4500 rpm ? Redline: 7400 rpm ? VTEC Engagement: 6000rpm K24A4 • Found in: o 2003-2005 Honda Accord, 2003-2006 Honda Element ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 9.7:1 ? Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008) ? Torque: 161 ft•lbf (218 N•m) @ 4500 rpm (@4000 rpm in 2007/2008) ? Redline: 6500 rpm K24A8 • Found in: o 2006-2007 Honda Accord ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm ? Compression: 9.7:1 ? Power: 166 hp (124 kW) @ 6000 rpm ? Torque: 160 lb•ft (217 N•m) @ 4000 rpm ? Redline: 6500 rpm o 2007-2008 Honda Element ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm ? Compression: 9.7:1 ? Power: 166 hp @ 5800 rpm ? Torque: 161 lb•ft (218 N•m) @ 4000 rpm ? Redline: 6500 rpm K24Z1 • Found in: o 2007-2008 Honda CR-V ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 9.7:1 ? Power: 166 hp @ 5800 rpm ? Torque: 161 ft•lbf @ 4200 rpm ? Redline: 6500 rpm K24Z2 • Found in: o 2008 Honda Accord LX/LX-P trim models ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 10.5:1 ? Power: 177 @ 6500 rpm ? Torque: 161 ft•lbf @ 4300 rpm ? Redline: 6800 rpm K24Z3 • Found in: o 2008 Honda Accord EX/EX-L trim models ? Displacement: 2354 cc ? Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) ? Compression: 10.5:1 ? Power: 190 @ 7000 rpm ? Torque: 162 ft•lbf @ 4400 rpm ? Redline: 7100 rpm |
Series L N R
L12A i-DSI
Stock L12A i-DSI engine • Available exclusively in the European domestic market Jazz (known as Fit in certain markets) and available with only a 5-speed manual transmission. o Displacement: 1246 cc o Bore x Stroke: 73.0 x 74.4 mm o Compression Ratio: 10.8:1 o Horsepower: 57 kW (78 hp) @ 5700 rpm o Torque: 110 N•m (85 lbf•ft) @ 2800 rpm o Variations: L12A1 L13A i-DSI • Sold as a 1.3 in the Japanese Fit and only available with the standard CVT. European version marketed as a 1.4 for the Jazz and City, and available with either 5-speed manual or CVT with 7-speed mode. Use in Australia Jazz GLi (base model) with 5-speed manual or stardand CVT. Available in other markets as well. European Civic 1.4 i-DSI has a standard 6-speed manual with an available 6-speed automated manual I-SHIFT transmission. • For 7gen Civic, City, Fit & Jazz o Displacement: 1339 cc o Bore x Stroke: 73.0 x 80.0 mm o Compression Ratio: 10.8:1 o Horsepower: 63 kW (84 hp) @ 5700 rpm o Torque: 119 N•m (88 lbf•ft) @ 2800 rpm o Variations: L13A1 (Fit/Jazz), L13A7 (European market Civic), L13A8 (European market City) • For 8gen Civic o Displacement: 1339 cc o Horsepower: 70 kW (95 hp) o Torque: 230 N•m (91 lbf•ft) o CO2 emission: 109g/km (for the Honda Civic Hybrid) L15A i-DSI • Available in the Fit Aria, Mobilio, and Partner in Japan. Offered in the Fit/Jazz and City in certain countries. o Displacement: 1496 cc o Bore x Stroke: 73.0 x 89.4 mm o Compression Ratio: 10.8:1 o Horsepower: 66 kW (89 hp) @ 5500 rpm o Torque: 131 N•m (97 lbf•ft) @ 2700 rpm L15A VTEC L15A1 engine bay with owner customizations (intake pipe, grounding wires, and conical air filter) • Available in the Fit, Fit Aria, Airwave, Mobilio, and Mobilio Spike in Japan. Sold throughout the world with 5-speed manual or CVT options in the Fit/Jazz and City. Canadian and US Fit models will have a 5-speed automatic instead of the CVT. o Displacement: 1496 cc o Bore x Stroke: 73.0 x 89.4 mm o Compression Ratio: 10.4:1 o Horsepower: 81 kW (109 hp) @ 5800 rpm o Torque: 143 N•m (105 lbf•ft) @ 4800 rpm o Variations: L15A1 (Fit/Jazz) The N series engine is one of few diesel engines produced by Honda for automobiles. DOHC N22A2 Specifications • Bore & Stroke: 85.0mm x 97.1mm • Cylinder Layout: inline 4 • Displacement: 2204 cc • Valve Configuration: 16 valve DOHC • Type: i-CTDi • Compression ratio: 16.7:1 • Max boost: 13.5 PSI (0.93 BAR) • Max power: 140hp @ 4000 rpm • Max torque: 251ft•lbf @ 2000 rpm • Redline: 4500rpm R16A • Found in: o 2007- Honda Civic (Singapore Local Market FD4) ? Displacement: 1595 cc ? Compression: 10.5:1 ? Bore & stroke: 81.0 x 77.4 mm ? Power: 123 bhp (125 PS, 93 kW) @ 6200 rpm Net horsepower ? Torque: 15.6 kgf•m (151 N•m, 113 lbf•ft) @ 4200 rpm Net hoursepower R18A1 • Found in: o 2006- Honda Civic (JDM FD1, USDM FA1, USDM FG1) ? Displacement: 1799 cc ? Compression: 10.5:1 ? Bore & stroke: 81.0 x 87.3 mm ? Power: 138 bhp (140 PS, 103 kW) @ 6300 rpm ? Torque: 17.7 kgf•m (174 N•m, 128 lbf•ft) @ 4300 rpm R18A2 • Found in: o 2007- Honda Civic (EDM FN1, EDM FK2) ? Displacement: 1799 cc ? Compression: 10.5:1 ? Bore & stroke: 81.0 x 87.3 mm ? Power: 138 bhp (140 PS, 103 kW) @ 6300 rpm ? Torque: 17.7 kgf•m (174 N•m, 128 lbf•ft) @ 4300 rpm R20A1 • Found in: o 2007- Honda Stream o 2007- Honda CRV ? Displacement: 1997 cc ? Compression: 10.5:1 ? Bore & stroke: 81.0 x 96.9 mm ? Power: 148 bhp (150 PS, 110 kW) @ 6200 rpm ? Torque: 19.4 kgf•m (190 N•m, 140 lbf•ft) @ 4200 rpm |
:) gracias compañero zapato djkaskdhasl |
buena información, de casualidad no tenes el manualito de este D17A2
• VTEC-E • Found in: o 2001-2005 Honda Civic EX o 2001-2005 Honda Civic Si (Canada only) ? Displacement : 1668 cm³ ? Bore and Stroke : 74.98 mm X 94.4 mm ? Compression : 9.9:1 ? Power : 127 hp @ 5800 rpm & 114 ft•lbf @ 4800 rpm ? Valvetrain : SOHC VTEC-E ? Fuel Control : OBD-2 MPFI órale, |
alagran diosa puta ñalsdkjfaksdf
no se entiende ni mierda |
el mio es:
D17A2
:dormir:
Buenas, a todos, neccesito saber donde puedo encontrar repuestos para mi accord 1992 2.0 litros a carburador y seria bueno tambien saber la serie de este modelo, lo acabe de comprar y neccesito informacion sobre este gran auto
Muchas Gracias |
La franja horaria es GMT -6. Ahora son las 12:07. |
