Este thread fue creado hace 1462 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
27-Jan-2010, 11:34 | #1 |
EL SHERIFF
firebird 67 / camaro 96
Tiempo: 13.14
significado de las luces del tablero
aca les dejo por si se les enciende alguna luz y no saben que es
1. ABS warning light – it is turned on every time there's something wrong with the Anti-lock Brake System. Note that the ABS symbol is activated once the drive starts the engine but it's automatically turned off after a few seconds. 2. Low fuel notification – this panel is switched on if the fuel level gets very low and refuel is required. 3. Seat belt reminder – the symbol appears and remains active as long as the engine is started and the seat belt remains unfastened; depending on the car manufacturer and car model, the seat belt reminder is combined with an audio notification. 4. Electrical problem warning – this light warns you that there's a problem with the electrical system of the car. 5. Brake system alert – the notification is powered on if the ECU detects a problem to the brake system 6. Warning light – it signals an unidentified problem with your car; it usually requires the car to be serviced. 7. Child seat indicator – if turned on, it informs you that the standardized child safety seat is attached 8. Tire pressure monitor – the warning is turned on in case of low tire pressure which could raise the fuel consumption or affect the grip. 9. Air filter – usually installed on the center console but also found on the dashboard, this light informs the driver that a malfunction was detected at the passenger compartment air filter 10. Front airbag – the light monitors the front airbag and, in case it is turned on, signals a problem with it; it usually requires professional assistance. 11. Side airbag – same as the front airbag but intended for the side airbag 12. Child seat – this symbol informs the driver that there may be a problem with the rear-mounted child seat; similar to number 7 but used by different manufacturers 13. Fog beams indicator – it is activated and remains on once the driver turns on the fog beams 14. Windshield wash – the notification appears once the windshield wipers are activated 15. Master lighting switch 16. Rear window defrost – pretty self-explanatory, it is turned on once the driver presses the rear window defrosting button 17. Child seat warning – similar to the other child seat notifications, it warns the driver that the child seat may be wrongly installed 18. Brake fluid malfunction – rarely installed on the dashboard, it unveils a problem in the brake fluid recipient 19. Battery warning – if this light is turned on while driving, it reveals a malfunction concerning the battery charging system 20. Child safety lock – if lighted on, the symbol shows you that the child safety lock has been activated 21. Emergency indicator – the notification is activated once the driver pushes the emergency button 22. Cruise control – this light is turned on if the cruise control system is activated; note that it may differ by brand and car model. 23. Windshield defrost – similar to rear window defrost but especially intended for windshield 24. Powertrain malfunction – if on, this light shows that the powertrain has been damaged and the car needs to be serviced as soon as possible. 25. Slip indicator – mostly installed on luxury cars, the slip indicator unveils that the car may lose grip due to difficult driving conditions 26. Open doors indicator – this symbol is usually turned on just after the driver starts the engine and informs him that one or more doors are closed incorrectly 27. Anti-theft system – exclusively installed on Ford models, this symbol flashes once the Securilock Anti-theft technology has been enabled 28. Electronic Throttle Control light – briefly enabled when the driver starts the engine, the indicator shows a malfunction in the Electronic Throttle Control system 29. AWD – with a pretty suggestive name, this panel is lighted on once the all-wheel drive system is enabled 30. ESP/BAS light – similar to the ABS indicator, but especially installed to inform the driver about a potential problem with the Electronic Stability Program technology 31. Overdrive indicator – it shows the driver that the overdrive system has been turned off 32. Turn signals – surely the most known instrument panels, the turn signals are activated once the driver changes direction and uses the signal lever 33. Temperature warning light – it warns the driver of the possibility of engine overheating and usually demands the driver to stop the vehicle 34. OBD Indicator – member of the Onboard Diagnostics, this indicators reveals a problem to the engine or to the gas emissions and required the car to be serviced. 35. High beam light – it is turned on once the driver activates the high beam mode of the headlights 36. Oil pressure warning – this notification is turned on if the ECU detects a problem with the oil pressure; the driver is usually recommended to stop the vehicle and service it as soon as possible. fuente http://www.autoevolution.com/news/ho...ghts-1370.html |
Créditos Awarded to z28 for this Post | |||
27-Jan-2010 | spike | info útil | 2 |
27-Jan-2010, 11:36 | #2 |
Fuck Yoli
EW3 - B202
Re: significado de las luces del tablero
La mera Verga |
27-Jan-2010, 12:16 | #3 |
En Español 1. Luz de advertencia del ABS? que se enciende cada vez que hay algo mal con el Anti-lock Brake System. Tenga en cuenta que el símbolo de ABS se activa una vez que la unidad se inicia el motor, pero es apaga automáticamente después de unos segundos. 2. La notificación de combustible de baja? este panel se enciende si el nivel de combustible se pone muy baja y es necesario abastecerse de combustible. 3. Recordatorio de cinturón de seguridad? El símbolo aparece y permanece activo mientras el motor está en marcha y sigue siendo el cinturón de seguridad desabrochado, dependiendo del fabricante y modelo del coche, el recordatorio del cinturón de seguridad se combina con una notificación de audio. 4. Alerta Problema eléctrico? esta luz le avisa de que hay un problema con el sistema eléctrico del coche. 5. Sistema de alerta de freno? la notificación está encendida, si se detecta un problema para el sistema de frenos 6. La luz de advertencia? que las señales de un problema no identificado con su coche, sino que por lo general requiere el coche para ser reparado. 7. Indicador de asiento infantil? si está activado, se le informa de que está conectado el asiento de seguridad estandarizados 8. Monitor de presión de neumáticos? la advertencia se activa en caso de presión de los neumáticos de baja que podría aumentar el consumo de combustible o afectar a la adherencia. 9. Filtro de aire? generalmente se instala en la consola central, pero también se encuentra en el salpicadero, esta luz informa al conductor que se detectó una avería en el compartimento de pasajeros del filtro de aire 10. Bolsa de aire frontal? la luz de los monitores de la bolsa de aire frontal y, en caso de que esté encendido, las señales de un problema con él, por lo general requiere de ayuda profesional. 11. Airbag lateral? igual que la bolsa de aire frontal, pero destinados a la bolsa de aire lateral 12. Asiento de niño? este símbolo informa al conductor de que puede haber un problema con la tracción trasera y el asiento infantil, similar al número 7, pero utilizados por diferentes fabricantes 13. Niebla vigas indicador? que se activa y permanece en una vez que el conductor se enciende la niebla vigas 14. Lavado de parabrisas? la notificación aparece una vez que los limpiaparabrisas se activan 15. Interruptor de alumbrado Master 16. Descongelación trasero? bastante explícito, que se enciende una vez que el conductor pisa el botón de la ventana posterior descongelación 17. De alerta de seguridad infantil? similares a las notificaciones de seguridad de otros niños, que avisa al conductor que el asiento de niño puede ser mal instalado 18. Mal funcionamiento del líquido de frenos? rara vez instalado en el salpicadero, que presenta un problema en el líquido de frenos destinatario 19. De alerta de la batería? Si esta luz está encendida durante la conducción, lo que revela un fallo relativo a la carga de la batería del sistema 20. De bloqueo de seguridad para niños? si encendidas en el símbolo muestra que el bloqueo de seguridad para niños ha sido activado 21. Indicador de Emergencia? la notificación se activa una vez que el conductor presiona el botón de emergencia 22. El control de crucero? esta luz está encendida, si está activado el sistema de control de crucero; en cuenta que pueden variar por marca y modelo de automóvil. 23. Descongelar parabrisas? similar a la de descongelación ventana trasera, pero especialmente destinados a parabrisas 24. Mal funcionamiento del tren motriz? si, este espectáculo de luces que el tren de potencia se ha dañado y el coche debe ser reparado lo antes posible. 25. Indicador de resbalamiento? se instalan en los coches de lujo, el indicador de resbalamiento revela que el coche puede perder adherencia debido a las difíciles condiciones de conducción 26. Abrir las puertas de indicadores? Este símbolo está activada habitualmente sólo después que el conductor enciende el motor y le informa de que una o varias puertas se cierran de forma incorrecta 27. Sistema anti-robo? instalada exclusivamente en los modelos de Ford, este símbolo parpadea una vez que la SecuriLock Anti-robo de tecnología se ha habilitado 28. De Control electrónico de aceleración de luz? brevemente activado cuando el conductor enciende el motor, el indicador muestra un mal funcionamiento en el sistema de control electrónico de aceleración 29. AWD? con un nombre muy sugerente, este panel se enciende una vez en todo el sistema de tracción está habilitado 30. ESP / BAS luz? similar al indicador de ABS, pero especialmente instalado para informar al conductor de un problema potencial con el Programa de Estabilidad Electrónica de tecnología 31. Indicador Overdrive? que muestra el controlador que el sistema Overdrive ha sido desactivado 32. Las señales de vuelta? sin duda los paneles de instrumentos más conocidos, se activan las señales de la vuelta una vez que el conductor cambia de dirección y utiliza la palanca de la señal 33. Luz de advertencia de temperatura? que avisa al conductor de la posibilidad de sobrecalentamiento del motor y por lo general exige al conductor que detenga el vehículo 34. OBD? miembro de la Diagnóstico a bordo, este indicador revela un problema en el motor o las emisiones de gas y necesita el coche para ser reparado. 35. Haz de luz de alta? que se enciende una vez que el conductor activa el modo de haz de alta de los faros 36. De alerta de presión de aceite? esta notificación se activa si se detecta un problema con la presión del aceite, el controlador se recomienda detener el vehículo y el servicio tan pronto como sea posible. |
27-Jan-2010, 12:25 | #4 |
RACING TEAM
Que buena info vos
27-Jan-2010, 12:40 | #5 |
Nunca te voy a olvidar
buen thread
27-Jan-2010, 12:47 | #6 |
Dark Lord
sohc / i-vtec
Tiempo: 11.4
Feedback Score: 46 reviews
Buen Thread Manin
y al que lo tradujo tambien buen trabajo |
27-Jan-2010, 13:00 | #7 |
***Special Agent***
NISMO & HONDA
Tiempo: Pi x pi
Interesante
El placer Supremo en la vida es el placer intelectual. "Aristoteles"
27-Jan-2010, 13:20 | #8 |
Driver
S13 - S14 - E30 - 4x4
Tiempo: Sideways
Feedback Score: 125 reviews
Buenisima info
27-Jan-2010, 19:36 | #9 |
starlet 95
27-Jan-2010, 21:26 | #10 |
rotary powaa!
rx7 fd3s
muy buena info gracias manin
27-Jan-2010, 21:42 | #11 |
solo el 25% habia visto
29-Jan-2010, 22:33 | #12 |
calidad la info!!!!
26-Jun-2015, 05:32 | #13 |
Respuesta: significado de las luces del tablero
Tengo un problema con mi honda 2006 enciende luz chek preste un escaner y me da el codigo 1129 dice mal funcionamiento de la manesilla de la puerta el piloto. No entiendo envtalleres me hicierin cambiar el map sensor nuevo y nada lo mismo si borro el codigo marcha bien solo si acelero. A fondo pierde fuerza y cabesea como q tuviera. Corte gas pero no se me dijeron tabien q la compu podria estar blockeada pero es cierto a las 5000rpm hace eso como q tuviera corte pero si le borro el codigo lo accelero afondo no pasa nada pasa de las 5000rpn y otros q podria ser el camshaft sensor q lo cabie me dicen q opinan uds o alguien le a pasado algo similar escucho respuesta les agradeseria. Si brindaran nad info grasias de su parte q tengan ub bueb dia..espero. Respuestas a mi orivkena
uploadfromtaptalk1435318224614.jpg esta es la fto del codigo q me tiro 1129 manesilla del piloto mal funcionamiento Enviado desde mi LG-D724 mediante Tapatalk |
20-Jul-2015, 08:56 | #14 |
que son Niebla Vigas en un volvo sefan 850 y como se apaga esa luz en el tablero
20-Jul-2015, 17:05 | #15 |
Italika
vos muy bien!!
24-Jul-2015, 11:04 | #16 |
Tratando de ser mejor
GTI
Tiempo: no me acuerdo
20-Aug-2015, 08:57 | #17 |
Excelente info
08-Sep-2015, 16:59 | #18 |
Mazda 6 mod 2004
Buenisima info
08-Sep-2016, 17:47 | #19 |
Tu mero Tata
BMW Pie \ Dodge Patas
Tiempo: Soleado asklñ
Buena info
08-Oct-2016, 11:45 | #20 |
Muy útil
10-Oct-2016, 09:35 | #21 |
jovenes disculpen mi ignorancia y aprovechando esto de los significados el mazda 3 2004 2.3 tiene abs y me tendria que marcar el simbolo en el tablero o no ? xq que yo recuerde no lo marca
saludos, |
23-Jun-2017, 08:58 | #22 |
Maestra Canchera
Toyota Land Cruiser
Disculpen que comente en un tema viejo pero las imagenes ya cayeron, podrias volver a subirlo? Por otra parte hay uno que parece espiral, que significa eso?
La compactera para autos determina el cuidado que tiene el dueño de la misma |
06-Jan-2019, 19:03 | #23 |
Excelente información! No sabía de algunas que están allí, pero gracias a todos por explicarlo a detalle.
15-Jan-2019, 01:31 | #24 | |
Enviado desde mi LDN-LX3 mediante Tapatalk |
23-Feb-2019, 07:36 | #25 |
Guest
Mensajes: n/a
ghosdf
