Electrónicos / Computadoras Venta de electrónicos, computadoras, consolas, etc. (3 créditos) |
Este thread fue creado hace 5319 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
28-Sep-2009, 21:41 | #1 |
Tiempo: naaa
Vendo tornamesas :alaputa:
Un buen amigo me pidio favor que pusiera esta chivas aqui, aquel no pertenece pero conoce del foro y ps alli ta alas ordenes para los que le gusta ese rollo
Articulo: TORNAMESAS DJ :alapowta: -------------------------------------------------------------------------| Modelo/Marca: : 1Dennon DNS1000 y 1 Stanton C.313. -------------------------------------------------------------------------| Especificaciones: The DN-S1000 is a small, compact, feature-rich CD/mp3 player carefully designed to fit the requirements of today's DJs. Whether you're a mobile DJ, club DJ, international DJ or just a novice, the DN-S1000 is packed with creativity, performance, experience and reliability. Brand new and weighing in at a mere 8 pounds, Denon's smallest CD/MP3 player packs high-end features not found in much larger units. Smaller is better. Fader start control terminal compatible with all Denon DJ mixers Digital outputs - constant digital output at 44.1 kHz is present when using all functions Hot start - two hot starts (A1 and A2) can be made on the fly and used as a stutter point as well. (CD or mp3) 100 mm long-stroke slider with center click for playback speed control Seamless loop - two seamless loops are available. (CD or mp3) Unit Dimensions - 8.89 x 3.62 x 8.46 inches (26 x 92 x 215 mm) S1000 Features: mp3 playback mp3 seamless looping w/ B point trim mp3 scratching mp3 hot starts, MP3 effects C.B.R. and V.B.R. encoding up to 320 kbps ID3 tags, displays (title, artist, album) mp3 file search system (locate your files by name fast and easy) Denon DN-S1000 Specifications: Advanced MP3 Functionality: Hot Start, Looping, Scratching, Effects, ID3 Tag Display,File Search System, Supports CBR./VBR Encoded Files Up to 320kbps 7 On-board Effects: Echo, Echo Loop, Flanger, Filter, Drag-S, Brake, Reverse Pressure Sensitive Scratch Disc Next Track Function w/Adjustable Cross Fade (Pick Your Next Track Beforehand and Crossfade Over to It!) 2 Hot Starts, Seamless Loops & Stutter Points per Track or Disc B Point Loop Trim (CD & MP3) CD Text Support Fast Loading Slot In drive 3-Way BPM Counter: Auto, Tap, Manual Input Pitch Ranges:± 4, ± 10, ± 16, ± 24, ± 100 2-way Pitch Bend: Buttons or Scratch Wheel Key Adjust:+100% / -99% Max Fast Search/Manual Search Instant Start (0.02sec) Customizable Paper Slipmats Internal Cue Point Memory Plays CD-R/RW Media Fader Start Compatible Constant Digital Output at 44.1 kHz (CD/MP3) Shock-Proof Memory: 16 Customizable Preset Functions Software Upgradeable by CDROM(for Future Use) Pairs up with the DN-X100 Compact Mixer Dimensions:8.89 (w) X 3.62 (h) X 8.46 (d) inches Denon Dn-s1000, Contador BPM - 4 efectos: Flanger, filtros (alto, medio y bajo), eco y eco loop - 3 efectos en el plato, pueden utilizarse indistintamente con CD o MP3: Drag-start, freno y reversa - Pitch control para CD y MP3 - Pitch bend - EOM, luz centelleante cuando detecta que se acerca el fin del track. Stanton - C.313 Professional CD/MP3 Player The Stanton C.313 is Stanton’s new workhorse tabletop CD player with MP3 functionality. The large jog wheel makes cueing tracks easy, while a 10-second anti-shock buffer eliminates embarrassing CD “skips.” The affordable C.313 even comes with digital features like Key Lock, seamless looping and four sample trigger buttons. Professional tabletop CD player with seamless looping and sampling Full MP3 functionality MP3 player-style file and folder browsing Large jog wheel makes cueing tracks more natural Key Lock (aka master tempo) Adjustable pitch (+/- 8%, 16%, 25%, 100%) and Pitch Bend Onboard sampling with four trigger buttons and cue memory Reliable, anti-shock playback with auto cue and instant playback Easy-to-read amber LCD keeps essential info at a glance S/PDIF digital output Description Measurement Frequencey Response 20 Hz to 20 kHz +/- 1.5 dB THD+N With 20 kHz Low Pass Filter 0.015% at 1 kHz S/N Ratio: With 20 kHz Low pass filter and IHF-A Weighted 85 dB Output Level +6 dBV (1 Vrms) +/- 1dB at 1kHz, 0dB Channel Balance Within 1 dB at 1kHz, 0dB De-Emphasis Response +3/-0 dB at 16kHz, -20 dB Channel Separation: With 20 kHz Low pass filter and IHF-A Weighted 90 dB at 1kHz, 0 dB Searching time: (Test Disc: TCD-792) Short Access Time: Long Access Time: 2 sec Play next Track 4 sec Track 1 to 20, 20 to 1 Playability: Interruption: Black Dot: Finger Prints: Eccentricity: Vertical Deviation: 0.7mm TDC-725 0.6mm TDC-725 65um TDC-725 140um TDC-712 W/O Track Jump 0.5mm TDC-731R Power Supply AC 120V, 60Hz, 15W Dimensions 318 (W) x92(H) x358(D) mm Weight 4.3 Kgs. -------------------------------------------------------------------------| Negocio: Venta -------------------------------------------------------------------------| Tiempo de uso: 6meses aprox -------------------------------------------------------------------------| Precio: Q5,800.00 negociables (Las dos tornamesas:Dennon DNS1000 y Stanton C.313) no se venden por separado -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: solo CASH, DANDO Y DANDO -------------------------------------------------------------------------| Estado general:Exelente estado -------------------------------------------------------------------------| Telefono o Contacto con el Vendedor: FRANCO GALLARDO cel. 54061816. Mail: [email protected]....... FOTOS: no tirar caca porfavor
28-Sep-2009, 21:43 | #2 |
FD3S
Re: Vendo tornamesas :alaputa:
freeee bump perra
estan nitidas |
28-Sep-2009, 21:46 | #3 |
Tiempo: naaa
28-Sep-2009, 21:46 | #4 |
Tiempo: naaa
28-Sep-2009, 21:47 | #5 |
:chupala:
Sr20 Mod. 2040
Tiempo: 3 seg :mono:
Feedback Score: 115 reviews
DJ tamal pa que ahora si tengas tornamesas dafñlskjdfldfa
http://kennetkda.elbruto.es/ |
28-Sep-2009, 21:53 | #6 |
Mod Toyotero
Tiempo: Waiti 10.7s
que buenas chivas vos sinpescueso
WWW.TOYOTACARCLUBGT.COM
28-Sep-2009, 21:55 | #7 |
Tiempo: naaa
gracias mucha alli tan a las ordenes por si saben de alguein
28-Sep-2009, 22:41 | #8 |
Tiempo: naaa
pilas ps se escuchan ofertas
29-Sep-2009, 18:40 | #9 |
Tiempo: naaa
pilas ps mucha
29-Sep-2009, 19:03 | #10 |
Señior Member
burras.
Tiempo: mucho xD
no le llego
aparte que no son iguales asldgjsa voy a tener que comprar las numark free bump |
29-Sep-2009, 19:42 | #11 | |
HIGH MUSIC
Honda Accord & Mitsu Colt
Tiempo: Lluvioso
Feedback Score: 46 reviews
sdcsjdcnsjdcnsdjcnsdc aaaawebos no son iwales.... ... almenos para mi, Stanton es como decir GEMINI pero ahora la marca DENON si su madre.... yo he probado las DNS-3500 y las DNS-5000 exceso de tornas... laaastima que solo estan vendiendo 1 y 1.... q raro.... no le alcanzo para el par de cada una a tu cuate o q onda!??? xq haria asi la compra?? bueeeeno cosa q a mi no m interesa.... suerte en la venta manin pd: cuales Numark pensas comprar!???
Traficando Musica de Alta. DJ TAVO MIX |
29-Sep-2009, 22:33 | #12 | |
Tiempo: naaa
29-Sep-2009, 22:51 | #13 | |
Señior Member
burras.
Tiempo: mucho xD
Numark Axis 4 |
30-Sep-2009, 17:44 | #14 |
HIGH MUSIC
Tiempo: Lluvioso
30-Sep-2009, 18:10 | #15 |
Señior Member
burras.
Tiempo: mucho xD
30-Sep-2009, 18:31 | #16 |
HIGH MUSIC
Tiempo: Lluvioso
01-Oct-2009, 10:51 | #17 |
Señior Member
burras.
Tiempo: mucho xD
01-Oct-2009, 10:57 | #18 |
HIGH MUSIC
Tiempo: Lluvioso
01-Oct-2009, 11:09 | #19 |
ps3,xbox360,WII,PC
Feedback Score: 189 reviews
03-Oct-2009, 23:16 | #20 |
www.rabinal.org
vos enano ya vendiste la torna?
03-Oct-2009, 23:36 | #21 |
MAZDA 3I 2011
uta m......... para q mas
03-Oct-2009, 23:49 | #22 |
FD3S
tamal cerote anda desvia tus thread de moteros mejor jueputa
y vos emo cerote mapreco tambien y me las tornamesas saber si las vendierion askja;ls |
