Feedback Score: 54 reviews
ayuda ford f150 2004
mucha quiero chingarlos resulta que me tope con el problema que no se como se sacan las candelas de un ford 150 5.4 2004 ya me quebre la cabeza nunca habia visto un carro de estos y otra cosa que tipo de candela usa o que numero ayudaaaaaa
Encaramado en una Cuca
V8
Tiempo: 20 min
Re: ayuda ford f150 2004
fijate que buscando algo con que poder ayudarte me tope con esto...
![]() Ford Engines - Spark Plug Defect Shane of Farmington NM (11/11/08) And another plug blew out...I give up. I will never buy another Ford truck!! Anyone looking to buy a F150 look out! How can they get away with such an incredibly bad design flaw! Plus they keep just blowing me off. I've been a Ford guy all my life till now..good going Ford. I'm now stuck with a junk truck! Brian of Lakewood CO (11/10/08) I have had a problem with the Ford Spark Plug Blow Out. I have a 2000 F-150 with a 5.4 Triton. The first time my plug blew out it was in June of 08. I had just started my truck and was leaving the scrap yard, about 30min from home. I went to Ford and they said they wold have to replace the head. So I got online and got a kit to fix it myself. Then, I was on my way to wok and the second one blew. First was the #2 cylinder then the second was the #6. This was around the middle of September. So I had to get it home and miss a day of work to get it fixed. Then I was up hunting around the 2nd of November about an hour and a half from home in the mountains, then the #7 blew. So I quit my hunting trip and got it back home to fix it. Jessica of Lakewood CA (11/10/08) We have a 2003 Ford Expedition, with an approx mileage 130k. In our case 2 Spark Plug blowouts, cylinder heads are costing us about $3,000 in costs/repairs. Just as we've been researching the web, we have read about complaints from angry owners this same problem. I am aware of class action lawsuits against Ford and would like more information regarding this please. As this is a matter of defected parts by Ford. I have yet not checked if this has caused physical damage, but this is costing us a big chunk of change from our wallets. y hay mas... desde 2002 ![]() http://www.consumeraffairs.com/autom...ord_spark.html
V8
Tiempo: 20 min
al parecer necesitas uno de estos...
Spark plug socket for Ford F150 ![]() This unique and patented design works on 2004-newer Ford F150 pickup trucks with 5.4 liter 3-valve Triton V8 engines.Socket end is 9/16 inch.Soft rubber insert holds and protects spark plug during removal and installation.Extension is part of the socket. Easily fits down spark plug tube in cylinder head.Socket has 3/8 inch drive for use with a ratchet or breaker bar. Price: $17.46 The product (Spark plug socket for Ford F150) is available in local stores near Vadnais Heights, MN 55127 listed below. You may click on the city or zip code to find more related products in that area. You may also search to see if the item is available in your local area, how far it is away from you and how to get there, and to find the contact information for the store. Simply enter your area code or name of city then click on the button below. Or you can enter your keyword and location on top of the screen to search for product / service / event available in your local area. |
#4 | |
V8
Tiempo: 20 min
puede que esto te sirva
![]() Cita:
#5 | |
V8
Tiempo: 20 min
lo traduje con google porque que hueva
asdñlkajsñdlkjasd Cita:
#6 |
En la U
Geo Tracker y Camaro Z28
Tiempo: No se todavia
vos esas candelas se sacan ..... con mucho cuidado jajajaja!!!
#7 |
#8 |
igual yo con el mustang me desilusione de la manera ke pone las cosas ford
![]() ya sirven mis pms sdfasfdasd |
#9 | |
V8
Tiempo: 20 min
pues fijate que ahorita que me decis de herramienta... andate a la saccion de SERVICIOS Y NEGOCIOS de este foro... ahi hay un chatio que vende de todo tipo de herramienta... yo parecia wiro en dulceria viendo tantas babosadas que tiene.. deberias de preguntarle.... o sino creo que las manda a traer... |
#10 |
V8
Tiempo: 20 min
es Diego GT...
aqui su anuncio... ![]() espero te sirva.. http://www.velocidadmaxima.com/forum...d.php?t=103477 |
#11 | |
#12 |
Oracle
Sportrac200hp/Mirage65hp
En la explorer esta dificil sacar las candelas, pero si se puede. Yo he cambiado mis candelas y por eso decidi ponerle de esas iridium que tardan un monton para no tener que cambiarlas cada poco. Según pude entender en los documentos, son las candelas que vienen de fabrica las que dan problema? o no?
#13 | |
V8
Tiempo: 20 min
no creo que sean las bujias.... porque dicen que en pleno funcionamiento estallan esas mierdas aslñdkjñaslkdjñalskdjñlkajsd asldkñjasñldksadj |
#14 | |
Oracle
Para verificar que tipo y medidas de candelas podes usar entra a la pagina de motorcraft, alli metes el vin del vehiculo y te muestra el catalogo que ellos tienen. http://www.motorcraft.com/catalog.do?goto=vin |
#15 | |
V8
Tiempo: 20 min
