ExclamationEste thread fue creado hace 3391 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
Antiguo 02-Jan-2009, 14:47   #1
206GTi
Avatar de 206GTi
Opiniones Caja DSG
bueno, quiero opiniones sobre esta caja mas q todo si han sabido de algun problema o algo que falle en los carros que la usan.
si alguien tiene link de reviews de la caja se lo agradeceria ya que he encontrado poca info, solo he encontrado del funcionamiento en si, pero quiero opiniones del comportamiento y que tan fiable es....
Gracias por los comments.
206GTi está desconectado   Responder Citando
Antiguo 02-Jan-2009, 14:58   #2
TRD-Power
EP3
Avatar de TRD-Power
Re: Opiniones Caja DSG
TRD-Power está desconectado   Responder Citando
Antiguo 02-Jan-2009, 15:09   #3
TRD-Power
EP3
Avatar de TRD-Power
Twin Clutch / Direct Shift Gearbox (DSG)
What it is, how it works
By Aaron Gold, About.com
Filed In:
  1. New Technology
DSG diagram showing seperate transmissions and twin clutches
© Volkswagen of AmericaMore Images (3)
The twin-clutch transmission, also known as the Direct Shift Gearbox (DSG), R-Tronic or S-Tronic, is an automated transmissin that can change gears faster than any other geared transmission. Twin-clutch transmissions can be shifted either manually or automatically. They deliver more power and better control than a traditional automatic transmission and faster performance than a manual transmission. Originally markted by Volkswagen and Audi as the DSG and R/S-Tronic transmission, twin-cluch transmissions are now being offered by other automakers.
The twin clutch/DSG is a development of the sequential manual transmission (SMT), which is essentially a fully-automated manual transmission with a computer-controlled clutch. Before we delve into the workings of the DSG, let's start with an explanation of the SMT.
SMT: The control of a manual with the ease of an automatic
Though it has appeared on a few passenger cars, the SMT is widely used in certain forms of racing and is featured on some exotic high-performance cars.
Cars with SMTs have a manual transmission with no clutch pedal; the clutch is automatically engaged. Most SMTs can be shifted automatically or manually, the latter using a shift lever or paddles on the steering wheel. The advantage to an SMT is that it uses a solid coupling, as opposed to a fluid coupling (torque converter) as used in a traditional automatic (including Tiptronic- or manumatic-style transmissions). As with a manual transmission, the SMT provides a direct connection between engine and transmission, allowing 100 percent of the engine's power to be transmitted to the wheels. The SMT provides more immediate response and ensures that the engine RPMs do not drop when the driver lifts off the accelerator (as happens with an automatic), giving her more precise control over power output.
SMTs can also perform matched-rev (or double-clutch) downshifts: When the driver downshifts, the SMT disengages the clutch, shifts to neutral, and re-engages the clutch. The SMT calculates what the engine RPMs will be in the next-lowest gear based on the current road speed, and revs the engine (and, since the clutch is engaged, the transmission) to that speed. It then disengages the clutch, shifts into the lower gear, and re-engages the clutch. The result is a smooth change with no jerk and no sudden deceleration.
SMTs have one major disadvantage, same as a manual: Power must be interrupted while the transmission changes gears.
Twin clutch: An SMT without the lag
The twin-clutch transmission all but eliminates the lag inherent in SMTs. The twin-clutch is essentially two gearboxes with a pair of clutches between them, one for odd gears, one for even gears. When the driver starts out, transmission #1 is in first gear and transmission #2 is in second. The clutch engages and the car starts out in first. When it's time to change gears, the transmission uses the clutches to swap transmissions. The #1 transmission immediately shifts to third gear. At the next change the transmission swaps transmissions again, and #2 shifts to fourth. The twin-clutch transmission's computerized controller calculates the next likely gearchange and shifts the "idle" transmission into that gear. The advantage is the speed of gearchanges: Volkswagen's DSG takes about 8 milliseconds to upshift. Compare that to the SMT in the Ferrari Enzo, which takes 150 ms to upshift. It's also significantly faster than a human: According to Audi, the A3 runs 0-60 in 6.9 seconds with a 6-speed manual and 6.7 seconds with the 6-speed DSG. Like the SMT, the DSG performs double-clutch downshifts and can skip gears (i.e. downshifting from 6th directly to 4th, 3rd, etc).
Driving with a twin-clutch transmission
Most twin-clutch transmissions, incliding Volkswagen's DSG, use a traditional P-R-N-D-S shift pattern. In the case of Volkswagen's DSG, the transmission can shift automatically in either normal (D) or Sport (S) modes. In Normal mode, the DSG shifts to the higher gears early in order to minimize engine noise and maximize fuel economy. In Sport mode the transmission holds the lower gears longer in order to keep the engine in its powerband. This is especially useful for turbocharged cars like Audi A3, Volkswagen GTI and VW Jetta GLI, since the turbocharger is only active at higher RPMs. Sport mode also provides more aggressive downshifts with slight accelerator pedal pressure. Manual mode is engaged by either sliding the shift lever to the side or pulling one of the paddles on the steering wheel. Once in manual mode, shifts are made by moving the shifter fore and aft or using the paddles (which are marked " " and "-"). If manual mode was engaged with the paddles, pulling and holding the upshift paddle returns the transmission to automatic mode, allowing the driver to quickly downshift to a lower gear for passing and then hand control back over to the transmission.
Antiguo 02-Jan-2009, 15:11   #4
206GTi
Avatar de 206GTi
buen video canche, pero yo dije experiencias jajajajjajaja
en resumen quiero saber si chingan o no ajjajaj
Antiguo 02-Jan-2009, 15:25   #5
Tato20VT
Obsessive Car detailer
Avatar de Tato20VT
20VT
toda caja x muy dsg, tiptronic, strnoic lo tronic ke sea siempre va a chingar mas ke una kaja manual!! keep it manual!!
Tato20VT está desconectado   Responder Citando
Antiguo 02-Jan-2009, 17:06   #6
ReLL1K
Avatar de ReLL1K
Forged fJCW R56
Tiempo: 13's @ 1/4
Feedback Score: 152 reviews
En algun foro popular de alguna marca del grupo vag talvez?? que le dieras al search "dsg problems o gearbox"
ReLL1K está desconectado   Responder Citando
Antiguo 03-Jan-2009, 11:26   #7
joseflou
Avatar de joseflou
segun los ingleses la dsg y la caja de r35 son unas de las mejores cajas
----BOXER ----
---2 STAGE---
-TWIN TURBO-
RSK = Rallye Sport Kompressor
joseflou está desconectado   Responder Citando
Antiguo 03-Jan-2009, 22:53   #8
Ivan
Walk!
Avatar de Ivan
Golf SR MkIV / GTI MkIII
Tiempo: 1:41:057 APC
mira vos.... como experiencia propia te puedo decir q es otro nivel manejar con DSG vos , definitivamente es un muy buen avance ya q mejora en cualquier aspecto el performance del carro y a la ves la economia en combustible.....
la comodidad tambien es increible, vas tranquilo manejando sin mover tus manos del volante
y acordate q si tenes DSG, tenes automatico tradicional, triptronic y DSG
en realidad me encanta y es dificil escoger entre manual y DSG, pero te digo q yo me quedo con DSG
, mi granito de arena
La Podadora!
VW for life!
Ivan está desconectado   Responder Citando
Antiguo 03-Jan-2009, 23:14   #9
TheEgo
Got hids?
Avatar de TheEgo
Tiempo: 1:43.28-9.62
Feedback Score: 57 reviews
ya va a venir el eurolover a contar que hiso testdrive del Gti aksjfkalsdjfaklsj
TheEgo está desconectado   Responder Citando
Antiguo 03-Jan-2009, 23:33   #10
Mtech330i
ಥ_ಥ
Avatar de Mtech330i
335i E93 / F30 335IH
Tiempo: Poof..
ni color q vas a sacar un leon de los nuevos y no sabes si entre manual o DSG
Mtech330i está desconectado   Responder Citando
Antiguo 04-Jan-2009, 00:40   #11
JJorge
JayCee
Avatar de JJorge
Golf GTI MkVII 2.0T
Es una caja bueniiiisima men!, yo tengo un GTI MkV y puta funciona de maravilla, responde muy bien, te ahorras un poco mas de plata por la gas, comodo al manejar y si queres puyar zampas la sport y puuta a la mierdaaaa! , ejemplo vas en 3era y la caja ya tiene lista la 4ta y la 2da por si queres acelerar o o ir mas despacio, no sentis los cambios y son bien rapidos
JayCee
GTI For Life
JJorge está desconectado   Responder Citando
Antiguo 04-Jan-2009, 01:51   #12
206GTi
Avatar de 206GTi
Iniciado por Ivan Ver Mensaje
Gracias manin
Iniciado por TheEgo Ver Mensaje
http://es.youtube.com/watch?v=gmMNRQ1GJ3o
ese video esta buenisimo, cabal se ve la eficiencia de la caja.
Iniciado por BMWZR Ver Mensaje
Cuando lo puse pensaba que lo podia comprar por que me ofrecieron un bajar el precio de los carros, pero ya me llamaron para decirme que no pueden bajarlos, por lo tanto no les llego
Iniciado por JJorge Ver Mensaje
no te da problemas de nada la caja? , sabes cuanto valdra el kit o como es el mantenimiento que hay que darle?
Pd. lo puse por q soñe con tener uno, pero no llegue, entonces que queda para cultura general
Antiguo 04-Jan-2009, 18:32   #13
MONOFARO
Avatar de MONOFARO
Yo Lo Maneje Este Finde Y Yo No Quiero Un Cambio Manual En El Proximo Que Me Pueda Comprar.es De Cine Como Funciona ,no Hay Tirones Y En Mi Caso Fue Un R32 Mk4 Y Alucine Yo Manejando Y Mas Cuando Lo Hizo El Dueño.
Hay Dos Cajas Dsg Una La Que Yo Probe Con 6 Velocidades Y El Nuevo Con 7 Velocidades.de Momento La De 7 Velocidades Solo Para Motores De Hasta 130 Hp. Y La 6 Velocidades Para El Resto De Motores.la Diferencia De 6 A 7 Velocidades Es Que La De 7 No Tiene Aceite En Su Interior Y El Mantenimiento Es Casi Nulo Y Pesa Menos.dar Clavos No Se Ninguna Persona Que Le HAYA Dado Clavos ,ni En La Prensa Tampoco Hablan De Clavos.
Mi Amigo Tiene Un Seat Altea Con 170.000km Y Cero Clavos ,el R32 11oooo Km Cero Clavos . Cada Version De Carro O De Motor Tiene Una Configuracion Diferente Al Ser Electronico. Asi El Dsg Del Seat Altea No Tiene El Misma Programacion Que El R32 .los Seat Nuevos Como El Nuevo Ibiza Lo Tienen En Opcion Con 7 Velocidades.el Futuro Ibiza Cupra Lo Montara Con 7 Velocidades Y 180 Hp 1.4 Twin Turbo (compresor Y Turbo)
Saludos
MONOFARO está desconectado   Responder Citando
Antiguo 04-Jan-2009, 18:48   #14
less_n
Avatar de less_n
Iniciado por Tato206GTI Ver Mensaje
no necesariamente, solo si el usuario es un estomago, de lo contrario no
less_n está desconectado   Responder Citando
Antiguo 04-Jan-2009, 22:09   #15
Ivan
Walk!
Avatar de Ivan
Iniciado por less_n Ver Mensaje
Antiguo 04-Jan-2009, 22:39   #16
206GTi
Avatar de 206GTi
Iniciado por MONOFARO Ver Mensaje
Saludos
muy buena opinion, el nuevo ibiza cupra se ve buenisimo, pero caro
Antiguo 04-Jan-2009, 22:54   #17
TheEgo
Got hids?
Avatar de TheEgo
no sabia q los MKIV traian DSG
Antiguo 04-Jan-2009, 23:04   #18
JJorge
JayCee
Avatar de JJorge
Golf GTI MkVII 2.0T
Iniciado por 206GTi Ver Mensaje
CERO clavos, lo del mantenimiento si te la debo
Antiguo 04-Jan-2009, 23:05   #19
Ivan
Walk!
Avatar de Ivan
Vw r32
Antiguo 04-Jan-2009, 23:47   #20
206GTi
Avatar de 206GTi
pero que no sepas es buena seña jajajajaj, como que no te a tocado meterle plata a la caja
Vw r32
según yo la caja era cosa nueva, si esta desde el mkiv quiere decir que si ya paso buenas pruebas
Antiguo 05-Jan-2009, 00:30   #21
ruba
Avatar de ruba
6LL
y lento.... es 3 decimas mas lento en aceleracion de 0-100 que el actual
ruba está desconectado   Responder Citando
Antiguo 05-Jan-2009, 01:45   #22
JJorge
JayCee
Avatar de JJorge
Golf GTI MkVII 2.0T
Es que como el carro esta nuevito y los servicios en la agencia
Antiguo 05-Jan-2009, 09:17   #23
206GTi
Avatar de 206GTi
Iniciado por ruba Ver Mensaje
eso no lo sabia, pero tal vez en alta ya demuestra toda la nueva tecnologia que trae... no se, pero pienso que es buena opcion un motor pequeño ya que si lo andas despacio el consumo debe ser bajo, he buscado specs del consumo pero no encuentro ni en la pagina de seat
Cabal, ahorita por la garantia y eso todo es lindo, pero me imagino que el kit para cambiar clutches no debe ser muy barato, pero esperemos que no haya que cambiarlo muy seguido
Antiguo 05-Jan-2009, 10:03   #24
h4ck7er
www.bmwclubgt.com
Avatar de h4ck7er
Mtripas
Tiempo: No c todavia!
en mi opinion y experiencia, es una caja automatica con botoncitos en el timon para hacer los cambios.
h4ck7er está desconectado   Responder Citando
Antiguo 05-Jan-2009, 11:25   #25
Mtech330i
ಥ_ಥ
Avatar de Mtech330i
Tiempo: Poof..
bueno yo tengo un cuate q tiene un bimmer SMG no c si es casi lo mismo pero el ya se hecho la caja 3 veces segun el x meter mal un cambio cuando va puyando.
La franja horaria es GMT -5. Ahora son las 18:18.
Page generated in 0,22142 seconds with 11 queries
