Retroceder   VelocidadMaxima.com > Compra, Venta y Negocios > Electrónicos / Computadoras
Electrónicos / Computadoras Venta de electrónicos, computadoras, consolas, etc. (3 créditos)
ExclamationEste thread fue creado hace 3030 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
Antiguo 28-Sep-2009, 22:41   #1
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
Vendo tornamesas :alaputa:
Un buen amigo me pidio favor que pusiera esta chivas aqui, aquel no pertenece pero conoce del foro y ps alli ta alas ordenes para los que le gusta ese rollo
Articulo: TORNAMESAS DJ :alapowta:
Modelo/Marca: : 1Dennon DNS1000 y 1 Stanton C.313.
Especificaciones:
The DN-S1000 is a small, compact, feature-rich CD/mp3 player carefully designed to fit the requirements of today's DJs. Whether you're a mobile DJ, club DJ, international DJ or just a novice, the DN-S1000 is packed with creativity, performance, experience and reliability. Brand new and weighing in at a mere 8 pounds, Denon's smallest CD/MP3 player packs high-end features not found in much larger units. Smaller is better. Fader start control terminal compatible with all Denon DJ mixers Digital outputs - constant digital output at 44.1 kHz is present when using all functions Hot start - two hot starts (A1 and A2) can be made on the fly and used as a stutter point as well. (CD or mp3) 100 mm long-stroke slider with center click for playback speed control Seamless loop - two seamless loops are available. (CD or mp3) Unit Dimensions - 8.89 x 3.62 x 8.46 inches (26 x 92 x 215 mm)
S1000 Features:
mp3 playback
mp3 seamless looping w/ B point trim
mp3 scratching
mp3 hot starts, MP3 effects
C.B.R. and V.B.R. encoding up to 320 kbps
ID3 tags, displays (title, artist, album)
mp3 file search system (locate your files by name fast and easy)
Denon DN-S1000 Specifications:
Advanced MP3 Functionality: Hot Start, Looping, Scratching, Effects, ID3 Tag Display,File Search System, Supports CBR./VBR Encoded Files Up to 320kbps
7 On-board Effects: Echo, Echo Loop, Flanger, Filter, Drag-S, Brake, Reverse
Pressure Sensitive Scratch Disc
Next Track Function w/Adjustable Cross Fade (Pick Your Next Track Beforehand and Crossfade Over to It!)
2 Hot Starts, Seamless Loops & Stutter Points per Track or Disc
B Point Loop Trim (CD & MP3)
CD Text Support
Fast Loading Slot In drive
3-Way BPM Counter: Auto, Tap, Manual Input
Pitch Ranges:± 4, ± 10, ± 16, ± 24, ± 100
2-way Pitch Bend: Buttons or Scratch Wheel
Key Adjust:+100% / -99% Max
Fast Search/Manual Search
Instant Start (0.02sec)
Customizable Paper Slipmats
Internal Cue Point Memory
Plays CD-R/RW Media
Fader Start Compatible
Constant Digital Output at 44.1 kHz (CD/MP3)
Shock-Proof Memory: 16 Customizable Preset Functions
Software Upgradeable by CDROM(for Future Use)
Pairs up with the DN-X100 Compact Mixer
Dimensions:8.89 (w) X 3.62 (h) X 8.46 (d) inches
Denon Dn-s1000, Contador BPM - 4 efectos: Flanger, filtros (alto, medio y bajo), eco y eco loop - 3 efectos en el plato, pueden utilizarse indistintamente con CD o MP3: Drag-start, freno y reversa - Pitch control para CD y MP3 - Pitch bend - EOM, luz centelleante cuando detecta que se acerca el fin del track.
Stanton - C.313 Professional CD/MP3 Player The Stanton C.313 is Stanton’s new workhorse tabletop CD player with MP3 functionality. The large jog wheel makes cueing tracks easy, while a 10-second anti-shock buffer eliminates embarrassing CD “skips.” The affordable C.313 even comes with digital features like Key Lock, seamless looping and four sample trigger buttons.
Professional tabletop CD player with seamless looping and sampling
Full MP3 functionality
MP3 player-style file and folder browsing
Large jog wheel makes cueing tracks more natural
Key Lock (aka master tempo)
Adjustable pitch (+/- 8%, 16%, 25%, 100%) and Pitch Bend
Onboard sampling with four trigger buttons and cue memory
Reliable, anti-shock playback with auto cue and instant playback
Easy-to-read amber LCD keeps essential info at a glance
S/PDIF digital output
Description Measurement
Frequencey Response 20 Hz to 20 kHz +/- 1.5 dB
THD+N
With 20 kHz Low Pass Filter 0.015% at 1 kHz
S/N Ratio:
With 20 kHz Low pass filter and IHF-A Weighted 85 dB
Output Level +6 dBV (1 Vrms) +/- 1dB at 1kHz, 0dB
Channel Balance Within 1 dB at 1kHz, 0dB
De-Emphasis Response +3/-0 dB at 16kHz, -20 dB
Channel Separation:
With 20 kHz Low pass filter and IHF-A Weighted 90 dB at 1kHz, 0 dB
Searching time: (Test Disc: TCD-792)
Short Access Time:
Long Access Time: 2 sec Play next Track
4 sec Track 1 to 20, 20 to 1
Playability:
Interruption:
Black Dot:
Finger Prints:
Eccentricity:
Vertical Deviation: 0.7mm TDC-725
0.6mm TDC-725
65um TDC-725
140um TDC-712 W/O Track Jump
0.5mm TDC-731R
Power Supply AC 120V, 60Hz, 15W
Dimensions 318 (W) x92(H) x358(D) mm
Weight 4.3 Kgs.
Negocio: Venta
Tiempo de uso: 6meses aprox
Precio: Q5,800.00 negociables (Las dos tornamesas:Dennon DNS1000 y Stanton C.313) no se venden por separado
Tiempo de entrega y forma de pago: solo CASH, DANDO Y DANDO
Estado general:Exelente estado
Telefono o Contacto con el Vendedor:
FRANCO GALLARDO cel. 54061816.
Mail:
frankz.gallardo.513@hotmail.com.......
FOTOS:
no tirar caca porfavor
Tipo de Archivo: jpg 1.jpg (28,9 KB (Kilobytes), 177 visitas)
Tipo de Archivo: jpg 2.jpg (37,0 KB (Kilobytes), 177 visitas)
Tipo de Archivo: jpg 3.jpg (36,1 KB (Kilobytes), 178 visitas)
Tipo de Archivo: jpg 4.jpg (26,8 KB (Kilobytes), 178 visitas)
JDM@axel está desconectado   Responder Citando
Antiguo 28-Sep-2009, 22:43   #2
erre
Avatar de erre
FD3S
Re: Vendo tornamesas :alaputa:
freeee bump perra
estan nitidas
erre está desconectado   Responder Citando
Antiguo 28-Sep-2009, 22:46   #3
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
Iniciado por erre Ver Mensaje
freeee bump perra
estan nitidas
gracias vos sdfvuhajkrufh
Antiguo 28-Sep-2009, 22:46   #4
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
Antiguo 28-Sep-2009, 22:47   #5
KeNneTKdA
:chupala:
Avatar de KeNneTKdA
Sr20 Mod. 2040
Tiempo: 3 seg :mono:
Feedback Score: 110 reviews
DJ tamal pa que ahora si tengas tornamesas dafñlskjdfldfa
http://kennetkda.elbruto.es/
KeNneTKdA está desconectado   Responder Citando
Antiguo 28-Sep-2009, 22:53   #6
ToyoRed
Mod Toyotero
Avatar de ToyoRed
Tiempo: Waiti 10.7s
que buenas chivas vos sinpescueso
WWW.TOYOTACARCLUBGT.COM
ToyoRed está desconectado   Responder Citando
Antiguo 28-Sep-2009, 22:55   #7
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
gracias mucha alli tan a las ordenes por si saben de alguein
Antiguo 28-Sep-2009, 23:41   #8
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
pilas ps se escuchan ofertas
Antiguo 29-Sep-2009, 19:40   #9
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
pilas ps mucha
Antiguo 29-Sep-2009, 20:03   #10
mapreco
Señior Member
burras.
Tiempo: mucho xD
no le llego
aparte que no son iguales asldgjsa
voy a tener que comprar las numark
free bump
mapreco está desconectado   Responder Citando
Antiguo 29-Sep-2009, 20:42   #11
djtavo_mix
HIGH MUSIC
Avatar de djtavo_mix
Honda Accord & Mitsu Colt
Tiempo: Lluvioso
Feedback Score: 46 reviews
Iniciado por mapreco Ver Mensaje
no le llego
free bump
sdcsjdcnsjdcnsdjcnsdc aaaawebos no son iwales.... ...
almenos para mi, Stanton es como decir GEMINI pero ahora la marca DENON si su madre.... yo he probado las DNS-3500 y las DNS-5000 exceso de tornas... laaastima que solo estan vendiendo 1 y 1.... q raro.... no le alcanzo para el par de cada una a tu cuate o q onda!??? xq haria asi la compra?? bueeeeno cosa q a mi no m interesa....
suerte en la venta manin
pd: cuales Numark pensas comprar!???
Traficando Musica de Alta.
DJ TAVO MIX
djtavo_mix está desconectado   Responder Citando
Antiguo 29-Sep-2009, 23:33   #12
JDM@axel
Avatar de JDM@axel
Tiempo: naaa
Iniciado por djtavo_evolution Ver Mensaje
las compro cuando empezo creo ahora aquel ya es full DJ y va a compar unas que cuestan como 5mil dolares cada una algo asi , yo no se ni que putas dicen solo le hice le favor de ponerlo pero llamale talves te dena la DENON
Antiguo 29-Sep-2009, 23:51   #13
mapreco
Señior Member
burras.
Tiempo: mucho xD
unas sencillas nomas
Numark Axis 4
Antiguo 30-Sep-2009, 18:44   #14
djtavo_mix
HIGH MUSIC
Tiempo: Lluvioso
Numark Axis 4
Mmmm y en cuanto te van a salir!????
mejor ajusta para las axis 9
Antiguo 30-Sep-2009, 19:10   #15
mapreco
Señior Member
burras.
Tiempo: mucho xD
esq esas si ya se salen totalmente de mi presupuesto
haber que pasa
esta semana o la otra talvez
Antiguo 30-Sep-2009, 19:31   #16
djtavo_mix
HIGH MUSIC
Tiempo: Lluvioso
haber que pasa
Mmmm y cuanto vas a pagar!??? y donde las vas a comprar!????
Antiguo 01-Oct-2009, 11:51   #17
mapreco
Señior Member
burras.
Tiempo: mucho xD
ebay
Antiguo 01-Oct-2009, 11:57   #18
djtavo_mix
HIGH MUSIC
Tiempo: Lluvioso
ebay
peeeero a como te van a salir!????
Antiguo 01-Oct-2009, 12:09   #19
maquina007
ps3,xbox360,WII,PC
Avatar de maquina007
Feedback Score: 188 reviews
par de s usen el msn
pd. suerte en la venta con las tornamesas vos
pd2. DJ TAMAL
maquina007 esta en línea ahora   Responder Citando
Antiguo 04-Oct-2009, 00:16   #20
rafagt
www.rabinal.org
Avatar de rafagt
vos enano ya vendiste la torna?
rafagt está desconectado   Responder Citando
Antiguo 04-Oct-2009, 00:36   #21
QH IRRA
MAZDA 3I 2011
uta m......... para q mas
QH IRRA está desconectado   Responder Citando
Antiguo 04-Oct-2009, 00:49   #22
erre
Avatar de erre
FD3S
tamal cerote anda desvia tus thread de moteros mejor jueputa
y vos emo cerote mapreco tambien
y me las tornamesas saber si las vendierion askja;ls
La franja horaria es GMT -5. Ahora son las 20:20.
Page generated in 0,44729 seconds with 11 queries
