Retroceder   VelocidadMaxima.com > Compra, Venta y Negocios > Repuestos / Accesorios para Vehículos
Repuestos / Accesorios para Vehículos Venta de repuestos o accesorios para cualquier vehículo (3 créditos).
Chiptuning de Guatemala
Reloj Bulova
¡Haz click aquí!
Tecnotrans
Netbooks 100% NUEVAS
ExclamationEste thread fue creado hace 2476 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
Antiguo 08-Jun-2006, 13:39   #1
RUBEN
SACUATE POWER
Avatar de RUBEN
INTEGRA DA6 ALL MOTOR!
Tiempo: 14.04 en 1/4
Feedback Score: 75 reviews
Para Los Turbosos
PRECIOS POR PM O CEL 5205-2378
TURBOXS BLOW OFF TYPE S
Our smallest valve, the BOV Type S is recommended for small to medium sized turbo charged
engines of less than 2.0 liters. Excellent flow in a compact package, the valve is perfect for your turbocharged Honda.
TURBOXS BLOW OFF TYPE H-RFL
With new and improved styling, the BOV-H-RFL remains true to it's roots - it's still really f'n loud! Like all our valves, the RFL relieves compressor pressure surge caused by changing gears or backing off the throttle and has been used on turbo charged engines running upto 35 psi boost. If you need to ask how loud it is, this valve is too loud for you! Blow Off Valve Type H-RFL comes standard with both a mild steel and aluminum weld-on adapters. Bolt-on kits are available for most OEM turbocharged applications.
HKS SQV BLOW OFF
HKS Super Sequential Blowoff Valves (SSQV) are dual stage pull type relief valves that by design do not leak under high boost conditions or under idle vacuum and is actuated by pressure alterations to ensure a quick primary and secondary valve response. more
GREDDY TYPE RS BLOW OFF ( KE LINDA ESTA ESTA SHIT !!! )
Created to be the most reliable blow off valve system available, the GReddy Type-RS's state-of-the art design allows for greater performance in a compact size. Improved response and increased pressure are achieved through carefully selected spring rates and a large 40mm valve. The real unique feature of the Type-RS blow off valve is the CNC machined 8 discharge ports that draw in the surrounding air to amplify the blow-off sound. The Type-RS is compatible with the standard GReddy Blow-off Valve flanges.
TURBOSMART BOOST CONTROL
Set your Boost and forget it! Boost is fully adjustable from under the hood. Easy adjustment. Gated System to bring boost on faster. Can be mounted with an included mounting bracket
TURBOXS BOOST CONTROL
Simple, inexpensive, and effective way to control your boost level and generate more power from your engine. Bleed type boost controller allows you to increase boost approximately 12psi over your wastegate boost setting.
TURBOXS HI PERFORMANCE BOOST CONTROL
Utilizing a uniquely engineered ball/spring mechanism combine with an adjustable bleed valve, the BC-HPBC allows you to spool your turbo to full boost up to hundreds of RPM faster than stock! The adjustable bleed mechanism lets you minimize the massive boost "spike" that can occur with poorly designed ball/spring manual boost controllers.
TURBONETIC BOSST CONTROL
Easy boost pressure adjustments!
Change your boost level from the cockpit of your car with these Turbonetics variable boost control kits. These boost controllers can adjust boost pressure on any external wastegate or factory dual port actuator. Kits can be adjusted from 0 psi to the indicated pressure levels.
RUBEN está desconectado   Responder Citando
Antiguo 08-Jun-2006, 14:30   #2
Toto
Hot Motors Racing Team
Avatar de Toto
Cuanto vale este boost controller?
Toto está desconectado   Responder Citando
Antiguo 08-Jun-2006, 14:33   #3
toshi
V6-24
Avatar de toshi
Iniciado por Toto
mejor el TurboSmart!!
toshi está desconectado   Responder Citando
Antiguo 09-Jun-2006, 04:07   #4
GTI-R
Jeet Kune Do
Avatar de GTI-R
Tiempo: 9.30 1/8
y la Greddy?
GTI-R está desconectado   Responder Citando
Antiguo 09-Jun-2006, 05:48   #5
GTturbo
CREW MEMBER
Avatar de GTturbo
SER Spec V
Muy interesado Ruben, decime cual es la que me dijiste que era para mi carro y cuanto??
GTturbo está desconectado   Responder Citando
Antiguo 09-Jun-2006, 07:21   #6
D16z_1.8T
Avatar de D16z_1.8T
Specialized
Tiempo: rapido
Feedback Score: 36 reviews
Question
Le quedara esta al Golf?
Solo para ponerla y ya?
Tipo de Archivo: jpg 216.jpg (17,8 KB (Kilobytes), 4 visitas)
D16z_1.8T está desconectado   Responder Citando
Antiguo 09-Jun-2006, 13:14   #7
RUBEN
SACUATE POWER
Avatar de RUBEN
Iniciado por D16z_1.8T
Le quedan todas.
Antiguo 09-Jun-2006, 13:14   #8
RUBEN
SACUATE POWER
Avatar de RUBEN
ya respondi a todas sus dudas , rebisen sus pms
Antiguo 09-Jun-2006, 15:24   #9
Gustavo
Avatar de Gustavo
VW GTI 2.0T
cuanto tenes la turbosmart?
Gustavo está desconectado   Responder Citando
Antiguo 09-Jun-2006, 15:31   #10
VWBetoGT
Grumpy Mod.
Avatar de VWBetoGT
Jing Sai speedsters :b6:
Grumpy MOD in da house!
VWBetoGT está desconectado   Responder Citando
Antiguo 09-Jun-2006, 16:28   #11
RUBEN
SACUATE POWER
Avatar de RUBEN
Iniciado por Gustavo
PM
Antiguo 09-Jun-2006, 17:17   #12
trd94
22C Freak
Avatar de trd94
cuanto la greddy blow off
y el turbonetics boost controler
trd94 está desconectado   Responder Citando
Antiguo 09-Jun-2006, 17:43   #13
Toto
Avatar de Toto
Gracias por contestarme vos
Antiguo 09-Jun-2006, 18:02   #14
Iniciado por Toto
Antiguo 09-Jun-2006, 19:03   #15
RUBEN
SACUATE POWER
Avatar de RUBEN
Iniciado por Bullitt
Antiguo 09-Jun-2006, 19:29   #16
truk360
struker
Avatar de truk360
era un lancer chiflador
HKS SQV BLOW OFF
cual es el precio de estos y cual me recomendas para mi Evo?
truk360 está desconectado   Responder Citando
Antiguo 10-Jun-2006, 10:23   #17
ravh
talvez me podes mandar un pm con el precio de la turbosmart. gracias
ravh está desconectado   Responder Citando
Antiguo 10-Jun-2006, 10:29   #18
Fredyracing
uuuhhh.....
Avatar de Fredyracing
Iniciado por truk360
HKS SQV BLOW OFF
price, price!!!! para el volvo!!
Fredyracing está desconectado   Responder Citando
Antiguo 27-Jun-2006, 14:15   #19
FAB
Avatar de FAB
Que tal ruben estoy interesado en un boost controller...te mande un PM
FAB está desconectado   Responder Citando
Antiguo 05-Jul-2006, 20:43   #20
Bmw_98
EX Gti_98.
Avatar de Bmw_98
vos estoy interesado en el boost controller, porfavor pm.
gracias.
Bmw_98 está desconectado   Responder Citando
Antiguo 05-Jul-2006, 20:51   #21
Cartman
shhhhhhhiiiiiaa
Avatar de Cartman
se le puede poner blow off a una Toyota Fortuner 3.0 Turbo Diesel Intercooler?
Cartman está desconectado   Responder Citando
Antiguo 09-Aug-2006, 22:49   #22
Julio109K
Te Garcheo!
Avatar de Julio109K
Chevy, Ford, MB, Skoda...
Tiempo: No tngo todav
hey a cuanto esta este?? se lo puedo adaptar a mi skoda octavia?
Julio109K está desconectado   Responder Citando
Antiguo 11-Aug-2006, 12:30   #23
RUBEN
SACUATE POWER
Avatar de RUBEN
Iniciado por Julio109K
3250.00
Podes comprar algo: Barato y bueno pero no bonito, bonito y barato pero no bueno, bueno y bonito , pero no barato.
Facebook: http://www.facebook.com/pages/Racing-Performance-Guatemala/312761452101226
sacuate@hotmail.com
TELEFONOS
2437-6250 / 5205-2378
Marcadores
La franja horaria es GMT -5. Ahora son las 22:55.
Page generated in 0,26674 seconds with 11 queries
