#101 |
Obsessive Car detailer
20VT
Re: *-*Que cera usar v. Hondatron *-*
Pooowta lito seria buenisimo ke te volvieras dealer de Poorboys, asi habria otra alternativa mas de productos, si no pues avisame cuando vayas a traer...
#102 |
20VT
Un pequeño review....
NXT 2.0 vs Poorboys Wheel Sealant I've been writing a lot (in the past) about how I was not happy with how NXT 2.0 performed on my wheels, so I thought I would write this review as a comparison between the NXT 2.0 vs. Poorboys Wheel Sealant. Having done the "car detailing" circuit, as well as other automotive forums, many people wrote about the virtues of Poorboys Wheel Sealant. A few weeks ago I painted my calipers on my Lexus IS350 and figured I'd do a comparison between NXT 2.0 and PWS. I had the wheels off the car so I really went at them. Here is what I found... PWS comes in a small tub and is bright pink in color. It has a very lousy smell to it (almost like gas or oil or some bad chemical) and is a paste like consistency. The tub it comes in, basically tells you that if you want "the maximum protection" three coats is the way to go. So, I did two coats of NXT 2.0 on the drivers side tires and THREE coats of PWS on the passenger side. For anyone who knows the IS350, it emits an ENORMOUS amount of brake dust (especially in the front). I don't drive my car all that much and only put about 100 miles on the car since the wax was applied. The application of the NXT was WAY easier. Went on smooth, dried quickly, much simpler. The PWS was longer and harder and took a long time to dry even though I put on a thin amount. Removal of the NXT was a breeze but removal of the PWS was a chore. However, having written all of that, the MOST IMPORTANT criteria was HOW EACH WORKED at repelling brake dust and ease of removal of the brake dust. The rate of repulsion was idential.... which really means neither did anything for repulsion. As for removal, I give a slight edge to the NXT 2.0. Not huge, but noticeable. Given all the factors outlined above, the PWS is back on the shelf, never to be used again. Sorry PWS, but you're hard to use, cost a lot (with shipping), smell terrible and most importantly, don't work as well as advertised. I think a lot of the internet hype I've read about PWS is exactly that, just hype. I think too many people assume that if they buy a product from a "boutique" type store, as opposed to the dreaded OTC products, they are getting better stuff. For me, results matter, not where I buy a product. In this case, when all of the factors are taken into consideration, I choose NXT 2.0, hands downs. I did not take photos, as illustrating brake dust and its EASE of removal are not really conducive to photos. |
#103 |
Lancer GTS
GTS
Tiempo: ¡!
![]() ![]() ![]() Yo ando iniciandome en el asunto este tambien, vivo te quiero con el tutorial. ![]()
#104 | ||
Offset is everything
Es como por ejemplo, visol te saca brillo, (incluso yo lo llamaria brillo cholero kalsjdalksdj) pero en la primer lavada, lluvia o dia soleado se cago la cosa laksjdlaskdj Cita:
![]() taba chingado mmbreeee ![]() se los prometo para el domingo antes de medio dia, con todo y fotos (prestadas pero, es mejor que nada alksdjalskjd)
#105 | |
*Professional Detailer*
#106 |
Es bastante interesante todos los comentarios que uno puede transmitir y adquirir en estos foros la verdad cada vez es mayor el numero de personas que preguntan y piden ayuda o tips de que productos pueden usar o que marca comprar y encontramos a cuates como "TATO206GTI" y "LITO2.0" que dan esos conocimietos y recomendaciones que la verdad mis respetos felicitaciones para estos dos cuates.
#107 | |
Depende de que, porque ellos tienen de todo... ponele un tarro de 8 onz de cera, $20, los swirl removers, $16 uno de 16 onz. pero el de 32 onz solo vale 10 dolares mas... te ahorras 7 dolares. comprando asi, y facil eso te alcanza para un par de años puliendo dos veces al año todos los carros de tu casa.
Lo increible es esto, estas marcas son "baratas" primero porque ellos vender su producto al por menor, no es el negocio... segun se, ellos venden su producto al por mayor y es re-envasado y vendido al doble ![]() Pero bueno, tambien esta menzerna, que es loooo menos por millones! y son ponele $10 mas caros que un poorboys.. vale la pena gastar mas. pero ya cuando supas comprar 5 productos si ya es pisto. Cita:
#108 |
Se me ooolvido tambien, gracias a Spike por los creditos, se te agradece mucho
#109 |
20VT
Yo de poorboys kiziera probar el natural look para interior y el famoso sellante de pintura, asi como algunas cosas de duragloss
Ahorita ke yo sepa no hay APC en la bodega Lito, yo hable con giovani ke es el representante aka en guate y me dijo ke en un mes masomenos |
#110 | |
![]() tambien seria bueno probar collinite, he visto mara que usa, un sellador, collinite insulator wax, y para mas joder un par de capas de swisswax ![]() Vos no has probado a traer cosas asi de los US? Mira yo hace como 3 años creo, compre cosas asi, unas me las traje en el avion y otras nos las trajeron... pero ahora saber si se puede ![]() |
#111 | |
20VT
#112 | |
#113 | |
basura no entiendo nada ![]() ![]() |
#114 | |
el foro ha muerto :(
un yaris
Tiempo: don't care
Feedback Score: 52 reviews
![]() si no estoy mal se refieren a los limpiadores todo propósito, que sirven para limpiar motores, interior, aros, llantas, etc... yo he utilizado limpiadores específicos para cada área, pero no he probado los apc e imagino que abundan más.... |
#115 |
Lancer GTS
GTS
Tiempo: ¡!
:leer: Creo que la bodega de El Pionero está por la Ave. Hincapie, abajito de los arcos de ladrillo, es de color azul sino estoy mal.
#116 |
20VT
APC (all porpouse Cleaner) te sirve para limpiar todo, dependiendo de la concentracion ke lo diluyas, y cabal ahi es la bodega
#117 |
#118 |
Lancer GTS
GTS
Tiempo: ¡!
#119 |
20VT
Bueno solo como tip...Ya vi ke kieren protoger sus carros con una buena cera, pero saben como mantener la cera?
#120 |
Lancer GTS
GTS
Tiempo: ¡!
#121 |
20VT
Bueno Primero para mantener la cera en la pintura, la clave es usar un shampoo que no remueva la cera, yo uso shampoos Meguiars
1.- Meguiars Gold Class, este es el top of the line de la linea de meguiars, Buena Limpieza, Buena lubricacion, Bastante Espuma y Facil de remover si tenes una buena cera te deja un look "Just Waxed" ![]() 2.- Meguiars NXT, por debajo del Gold Class, basicamente es mejor en limpieza que el Gold Class, remueve mas facil la suciedad, buena lubricacion, bastante espuma y facil de remover, lo deja muy brilloso pero no tanto como el gold class (Este es el que uso yo y el medio galon me duro un año lavandolo semanalmente) ![]() Aca les dejo un videin de la forma correcta de lavar sus carros http://www.webridestv.com/showvideo.aspx?video=43655 Solo como tip, para calcular la onza por galon que se requiere para un carro, lo ke hize fue con una geringa de 10CC llenarla 3 veces (30cc=1oz) en un vasito y marque en la medida correcta como explika el video |
#122 |
Got hids?
Tiempo: 1:43.28-9.62
Feedback Score: 57 reviews
donde venden, para pulir de 3m y barato?
#123 |
Lancer GTS
GTS
Tiempo: ¡!
Yo ahorita me estoy terminado el Turtle Zip Wax, pero cabal quewría ver que otro se puede usar. Esos shampoos, a que precio más o menos andaran.
#124 | |
20VT
el nxt como 80 el medio galon el gold como 110 |
#125 | |
Dark Lord
sohc / i-vtec
Tiempo: 11.4
Feedback Score: 46 reviews
vos yo fui a cemaco a comprar shampoo meguiar's y no habia ![]() PD: ando buscando hand Glaze.. hay algo similar de meguiars que sirva para lo mismo? |
