Retroceder   VelocidadMaxima.com > Automovilismo > Fotos / Videos de Automovilismo
Fotos / Videos de Automovilismo Fotos y videos relacionados con el automovilisimo, motos, etc... NO PORN! Just car porn :)
ExclamationEste thread fue creado hace 1373 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
Antiguo 12-Oct-2014, 10:15   #1
mil
1000
Avatar de mil
Valtonen fd rx7
Valtonen Motorsport’s 1995 FD3S Mazda RX-7
Engine
Nissan SR20VET, stock Pulsar GTI-R crankshaft, modified Pulsar oil pump (still running wet oil sump), Accusump, custom conrods, custom CP forged pistons, custom billet main girdle, ARP studs from Mazworks, Power Enterprise head gasket, ATI damper, ACL Race Series bearings, modified oil channels in block and pump, modified chain tensioner, Tomei adjustable timing gears, Kelford camshafts, modified rocker arms, Supertech valve springs, Supertech liners, Supertech oversized valves, titanium retainers, custom intake manifold, ID2300 injectors, 70mm custom billet throttle body, custom exhaust manifold, Holset HX50/55 turbocharger (71.5mm inlet/80mm exhaust), TiAL 60mm wastegate, 4.5-inch exhaust with custom muffler, Garrett intercooler with custom core tanks, custom hard piping, 4x Bosch Motorsport fuel pumps, custom catch tanks, Haltech Sport 2000 engine management system (will be updated to Elite soon), BMW coils, Denso Iridium spark plugs
Driveline
Tractive RD90 5-speed sequential gearbox with shift cut, custom chromoly flywheel, Alcon 7.25-inch triple-plate clutch, custom bellhousing, custom release bearing, custom propshaft and driveshafts, BMW 210 type differential with Carbonetic LSD (custom plates manufactured)
Suspension/ Brakes
Steering swapped to left-hand drive with Ford Sierra Cosworth rack, custom front control arms, modified front uprights (still in prototype), modified stock rear suspension set up, Nitron racing shocks, Alcon 6-piston brake callipers front/rear, 370mm front and 355mm rear discs, Carbonetics brake pads, Tilton pedalbox with modified wider brake pedal, HEL brake hoses
Wheels/Tyres
ADVAN 18×10.5-inch (front), 18×12-inch (rear) wheels , 270-300 tyres (front) 300-345 (rear) with various different brands used depending on conditions
Exterior
FD3S Mazda RX-7 replicated in carbon fibre with custom aerodynamic modifications throughout, still in development
Interior
Valtonen Motorsport display measures/logs: speed – rear wheel and GPS speeds, 5x exhaust temps, Lambda, boost pressure, water temp and pressure, oil temp and pressure, intake temp, transmission and differential temp, 4x tyre temps, gear and flat-shift force sensor, turbo RPM, engine RPM, battery voltage, fuel level, current fuel consumption, average fuel consumption, brake pressure front and rear, throttle position/target boost pressure/missed trigger counter (all for diagnostic purposes, display also controls windscreen wiper, indicators, brake lights – which strobe when locked up), radio, flat-shift, overtake button, telemetry to pit display, display system is connected to the ECU by CAN bus and can be expanded as needed with as many analog, digital and EGT channels as needed, MOMO steering wheel, Sparco Evo 2 seat, Sparco harness, Happy Racer passenger seat and harness
Milito
mil está desconectado   Responder Citando
Antiguo 12-Oct-2014, 10:50   #2
Charly Za
Wttff
Avatar de Charly Za
Feedback Score: 166 reviews
Respuesta: Valtonen fd rx7
Se ve moustruosamente poderoso
Charly Za está desconectado   Responder Citando
Antiguo 12-Oct-2014, 10:53   #3
Ghostbly
SUV
Avatar de Ghostbly
carbon aqui... carbon alla
Antiguo 12-Oct-2014, 11:05   #4
jocahe_119
fresco
Avatar de jocahe_119
jocahe_119 está desconectado   Responder Citando
Antiguo 12-Oct-2014, 21:40   #5
Sam
senior miembro!!
Avatar de Sam
Re: Valtonen fd rx7
Motor de Nissan? controlador de s2000, coils de BMW, que mezlca, tienen que saber lo que hacen.
No dice cuanto tira?
Sam está desconectado   Responder Citando
Antiguo 14-Oct-2014, 22:28   #6
TITIO
Club Jalapa
Avatar de TITIO
SI/TS
Tiempo: ......
Re: Valtonen fd rx7
#RedStar... "Old Racers Jalapa"
TITIO está desconectado   Responder Citando
Antiguo 15-Oct-2014, 16:46   #7
_jko_
Avatar de _jko_
MayaTour
me gustaría mas el brap brap brap brap brap...
_jko_ está desconectado   Responder Citando
Antiguo 17-Oct-2014, 13:30   #8
boombox
Subaru Love
Avatar de boombox
EJ25
Tiempo: 9.8
que exceso
+ Caracol =
boombox está desconectado   Responder Citando
Antiguo 17-Oct-2014, 13:35   #9
henryDVS
Vip Junior
Avatar de henryDVS
EG9 SIR
Feedback Score: 95 reviews
manejar esa maquina
henryDVS está desconectado   Responder Citando
Antiguo 21-Oct-2014, 16:14   #10
blackacur
Avatar de blackacur
que nivel
BIMMER
blackacur está desconectado   Responder Citando
Antiguo 22-Oct-2014, 15:17   #11
TEAM_SAML
TEAM SAML
Avatar de TEAM_SAML
solo el chasis de rx7.
Antiguo 10-Apr-2020, 09:33   #12
neliascarias
Avatar de neliascarias
Enviado desde mi LYA-L09 mediante Tapatalk
neliascarias está desconectado   Responder Citando
Antiguo 13-May-2020, 07:29   #13
rafael10
Esta guapisimooo!!!
rafael10 está desconectado   Responder Citando
Antiguo 15-Jul-2020, 21:20   #14
mariomunoz7
Esta Buenisimo
mariomunoz7 está desconectado   Responder Citando
La franja horaria es GMT -6. Ahora son las 09:30.
Page generated in 0,31946 seconds with 11 queries
