Este thread fue creado hace 3768 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
20-Feb-2014, 16:57 | #1 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
Feedback Score: 105 reviews
Memorias USB de 8GB y 16GB / SanDisk baratus pase adelante!!!
Articulo: Memoria USB de 16GB
-------------------------------------------------------------------------| Modelo/Marca: Cruzer Orbit / SanDisk -------------------------------------------------------------------------| Especificaciones: http://www.sandisk.es/products/usb/drives/cruzer-orbit/ Compact Swivel Design Offers Portability and Protection The Cruzer Orbit USB Flash Drive is less than 1,5 inches long and just over a quarter-inch thick, so it's easy to slip in a pocket, backpack, or purse. The flash drive's 360-degree, rotating cover shields the USB connector when it's not in use. Easily attach it to a key ring, three-ring binder, or lanyard for easy portability. High-Capacity Flash Drive Accommodates Large Media Files Available in capacities up to 32GB, this USB drive lets you carry your personal documents and favorite media with you. The drive is large enough to accommodate high-volume files such as videos, photos, music, and office documents. Simple, Drag-and-Drop File Transfer Transferring files to the drive is easy: simply plug it into an available USB port and drag the desired files into the drive's folder. No additional software or drivers are required, so you can begin transferring and backing up your files immediately. El software SecureAccess de SanDisk protege la privacidad de los archivos The Cruzer Orbit USB Flash Drive comes with SanDisk SecureAccess software, which creates a password- protected folder for your sensitive files. The application uses 128-bit AES encryption, so you'll be able to share your favorite media and USB flash drive while protecting your private documents from unwanted access. -------------------------------------------------------------------------| Negocio: Venta o Cambio por $$ -------------------------------------------------------------------------| Tiempo de uso: 0 KM -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: Lo ve si le gusta se lo lleva, tiene garantia de fabrica -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: cayendo el muerto y soltando el llanto, entrego por las mañanas en la usac y despues de medio dia en la zona 5, puedo enviar por cualquier medio previo deposito y el comprador corre con los cargos por envio -------------------------------------------------------------------------| Precio: Q116.00 -------------------------------------------------------------------------| Negociable? NO o talvez, talvez me convence de bajarle Q5 lajksdlñsjk -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso. -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 58545889 o 58215685 o por PM -------------------------------------------------------------------------- Fotos. Articulo: Memoria USB de 8GB -------------------------------------------------------------------------| Modelo/Marca: Cruzer Fit / SanDisk -------------------------------------------------------------------------| Especificaciones: Esta memoria es IDEAL para los que tienen radios con USB enfrente ya que no ocupa nada de espacio y tiene capacidad para bastante musica trae compatibilidad para USB 3.0. http://www.sandisk.es/products/usb/drives/cruzer-fit/ Low-Profile Form Factor for Easy Connections The drive's low-profile design allows it to easily connect to any USB device. Connect it to hard-to-access TV USB ports for HD video play back or bring your entire music library to your car via the USB port on your vehicle's audio system. The flash drive comes with a protective cap, which shields the USB connector from damage when not in use. High-Capacity Drive Holds Music, Video, Photos, and Personal Files Despite its compact size, the Cruzer Fit USB flash drive packs enough capacity for your favorite files and your most critical personal data. Available in capacities up to 64GB, the drive can accommodate photos, songs, and whatever else you need to carry. Add Files Easily with Drag-and-Drop File Loading It's easy to add files to the Cruzer Fit USB flash drive: just plug the USB drive into your computer's USB port and drag your files into the drive's folder. You don't need to download drivers or install software to use it, so you can start storing, transporting, and sharing your data immediately. SanDisk SecureAccessSoftware Protects Your Private Files The Cruzer Fit USB flash drive comes with SanDisk SecureAccess, which creates a password-protected private folder on your flash drive. With your private files protected with 128-bit AES encryption, you'll be able to share your USB drive without compromising your privacy. -------------------------------------------------------------------------| Negocio: Venta o Cambio por $$ -------------------------------------------------------------------------| Tiempo de uso: 0 KM -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: Lo ve si le gusta se lo lleva, tiene garantia de fabrica -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: cayendo el muerto y soltando el llanto, entrego por las mañanas en la usac y despues de medio dia en la zona 5, puedo enviar por cualquier medio previo deposito y el comprador corre con los cargos por envio -------------------------------------------------------------------------| Precio: Q75.00 -------------------------------------------------------------------------| Negociable? NO o talvez, talvez me convence de bajarle Q5 lajksdlñsjk -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso. -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 58545889 o 58215685 o por PM -------------------------------------------------------------------------- Fotos. Articulo: Memoria USB de 8GB -------------------------------------------------------------------------| Modelo/Marca: Cruzer Edge / SanDisk -------------------------------------------------------------------------| Especificaciones: http://www.sandisk.es/products/usb/drives/cruzer-edge/ Simple Slider Design Protects USB Connector The Cruzer Edge USB flash drive features a sleek, streamlined design that easily slips into your pocket. You can retract the USB connector using the flash drive's slider, protecting it from damage when it's not in use. The flash drive also has a stylish black and red finish that coordinates with many electronic devices. High-Capacity Drive Accommodates Your Favorite Media Designed by the pioneers of flash memory, the Cruzer Edge USB flash drive packs a generous capacity into a compact USB drive. Available in sizes up to 64GB, the flash drive can accommodate photos, songs, videos, and all of your personal data. Drag-and-Drop File Backup Is Easy and Fast Adding files to the Cruzer Edge USB flash drive is easy: just plug it into your computer's USB port and drag files into the drive's folder. No additional drivers or software are necessary, so you can store, transport, and share your data immediately. SanDisk SecureAccess Software Creates Password-Protected Folder The Cruzer Edge USB flash drive includes the exclusive SanDisk SecureAccess software, which protects a private folder on your flash drive with a password. Your private files are safeguarded with 128-bit AES encryption, so you can share your USB drive without compromising your privacy. -------------------------------------------------------------------------| Negocio: Venta o Cambio por $$ -------------------------------------------------------------------------| Tiempo de uso: 0 KM -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: Lo ve si le gusta se lo lleva, tiene garantia de fabrica -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: cayendo el muerto y soltando el llanto, entrego por las mañanas en la usac y despues de medio dia en la zona 5, puedo enviar por cualquier medio previo deposito y el comprador corre con los cargos por envio -------------------------------------------------------------------------| Precio: Q65.00 -------------------------------------------------------------------------| Negociable? NO o talvez, talvez me convence de bajarle Q5 lajksdlñsjk -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso. -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 58545889 o 58215685 o por PM -------------------------------------------------------------------------- Fotos. Articulo: Memoria USB de 8GB -------------------------------------------------------------------------| Modelo/Marca: Cruzer Blade / SanDisk -------------------------------------------------------------------------| Especificaciones: http://www.sandisk.es/products/usb/drives/cruzer-blade/ Compact Design for Maximum Portability The Cruzer Blade USB flash drive features a compact design that fits easily into a pocket or computer bag. This USB drive has a sleek black and red design that coordinates with many electronic devices. High-Capacity Drive Accommodates Your Favorite Media Files Designed by SanDisk, a USB in flash memory innovation, the Cruzer Blade USB flash drive packs generous capacity into a compact form. Available in sizes up to 64GB, this USB drive can hold all your must-have files. Simple Drag-and-Drop File Backup Transferring data onto the Cruzer Blade USB flash drive is easy: simply plug it into your computer's USB port and drag files into the drive's folder. After a fast, first time driver download, this USB drive lets you start storing, transporting, and sharing your data immediately. SanDisk SecureAccess Software Protects Drive from Unauthorized Access The Cruzer Blade USB flash drive comes with the exclusive SanDisk SecureAccess , which creates a password- protected private folder on your flash drive. SanDisk SecureAccess software uses 128-bit AES encryption, so you'll be able to share the files you want while keeping your private files locked. -------------------------------------------------------------------------| Negocio: Venta o Cambio por $$ -------------------------------------------------------------------------| Tiempo de uso: 0 KM -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: Lo ve si le gusta se lo lleva, tiene garantia de fabrica -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: cayendo el muerto y soltando el llanto, entrego por las mañanas en la usac y despues de medio dia en la zona 5, puedo enviar por cualquier medio previo deposito y el comprador corre con los cargos por envio -------------------------------------------------------------------------| Precio: Q65.00 -------------------------------------------------------------------------| Negociable? NO o talvez, talvez me convence de bajarle Q5 lajksdlñsjk -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso. -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 58545889 o 58215685 o por PM -------------------------------------------------------------------------- Fotos. Articulo: Memoria USB de 8GB -------------------------------------------------------------------------| Modelo/Marca: Cruzer Orbit / SanDisk -------------------------------------------------------------------------| Especificaciones: http://www.sandisk.es/products/usb/drives/cruzer-orbit/ Compact Swivel Design Offers Portability and Protection The Cruzer Orbit USB Flash Drive is less than 1,5 inches long and just over a quarter-inch thick, so it's easy to slip in a pocket, backpack, or purse. The flash drive's 360-degree, rotating cover shields the USB connector when it's not in use. Easily attach it to a key ring, three-ring binder, or lanyard for easy portability. High-Capacity Flash Drive Accommodates Large Media Files Available in capacities up to 32GB, this USB drive lets you carry your personal documents and favorite media with you. The drive is large enough to accommodate high-volume files such as videos, photos, music, and office documents. Simple, Drag-and-Drop File Transfer Transferring files to the drive is easy: simply plug it into an available USB port and drag the desired files into the drive's folder. No additional software or drivers are required, so you can begin transferring and backing up your files immediately. El software SecureAccess de SanDisk protege la privacidad de los archivos The Cruzer Orbit USB Flash Drive comes with SanDisk SecureAccess software, which creates a password- protected folder for your sensitive files. The application uses 128-bit AES encryption, so you'll be able to share your favorite media and USB flash drive while protecting your private documents from unwanted access. -------------------------------------------------------------------------| Negocio: Venta o Cambio por $$ -------------------------------------------------------------------------| Tiempo de uso: 0 KM -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: Lo ve si le gusta se lo lleva, tiene garantia de fabrica -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: cayendo el muerto y soltando el llanto, entrego por las mañanas en la usac y despues de medio dia en la zona 5, puedo enviar por cualquier medio previo deposito y el comprador corre con los cargos por envio -------------------------------------------------------------------------| Precio: Q70.00 -------------------------------------------------------------------------| Negociable? NO o talvez, talvez me convence de bajarle Q5 lajksdlñsjk -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso. -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 58545889 o 58215685 o por PM -------------------------------------------------------------------------- Fotos. Articulo: Memoria USB de 8GB -------------------------------------------------------------------------| Modelo/Marca: Cruzer Pop / SanDisk -------------------------------------------------------------------------| Especificaciones: http://la.sandisk.com/products/usb/drives/cruzer-pop/ Diseño moderno y compacto que se adapta en la billetera La unidad flash USB SanDisk Cruzer Pop, un accesorio ideal para los usuarios de datos que aman divertirse, presenta una estética única inspirada en el arte urbano. Está disponible en varios diseños, por lo que puedes elegir una unidad que se complemente con tu estilo personal. Esta unidad USB, que mide menos de 4 mm de ancho, se adapta fácilmente a tu bolsillo, billetera o carpeta. El conector USB oculto preserva tus datos La unidad Cruzer Pop presenta un diseño plegable, con bisagras, que oculta el conector USB y puede abrirse cuando ya estás listo para usarla. La cubierta integrada protege el conector USB de daños y desgaste, para que los archivos siempre estén protegidos. Capacidades generosas que se adaptan a los archivos más grandes La unidad Cruzer Pop, disponible en capacidades de hasta 32 GB, tiene espacio suficiente para almacenar todos tus archivos importantes. Tus fotografías favoritas, canciones, documentos y otros elementos personales siempre estarán allí cuando los necesites. Fácil transferencia de archivos plug and play (conectar y listo) Para agregar archivos a la unidad Cruzer Pop, simplemente conecta la unidad USB al puerto USB de tu computadora y arrastra los archivos deseados a la carpeta de Cruzer Pop. No se requieren controladores ni instalaciones. El software SanDisk SecureAccess protege tus archivos privados La unidad flash USB SanDisk Cruzer Pop incluye el software SanDisk SecureAccess, que crea una carpeta protegida por contraseña para todos tus archivos confidenciales. Tus archivos estarán protegidos con la codificación AES de 128 bits, por lo que podrás compartir tu unidad sabiendo que tu información confidencial está segura. -------------------------------------------------------------------------| Negocio: Venta o Cambio por $$ -------------------------------------------------------------------------| Tiempo de uso: 0 KM -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: Lo ve si le gusta se lo lleva, tiene garantia de fabrica -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: cayendo el muerto y soltando el llanto, entrego por las mañanas en la usac y despues de medio dia en la zona 5, puedo enviar por cualquier medio previo deposito y el comprador corre con los cargos por envio -------------------------------------------------------------------------| Precio: Q75.00 -------------------------------------------------------------------------| Negociable? NO o talvez, talvez me convence de bajarle Q5 lajksdlñsjk -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 5pts: NUEVO, nuevo significa en su caja original, con todos su manuales y accesorios, sin rayones, cero uso. -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 58545889 o 58215685 o por PM -------------------------------------------------------------------------- Fotos.
Buscando Infractores :iseeyou: alskdj |
20-Feb-2014, 17:15 | #2 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
Respuesta: Memorias USB de 8GB y 16GB / SanDisk baratus pase adelante!!!
pregunte sin ningun compromiso alkdjkljd
20-Feb-2014, 17:46 | #3 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
20-Feb-2014, 18:07 | #4 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
20-Feb-2014, 18:08 | #5 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
negociables jovenes un poquito poquito poquito alskdjlñkj
20-Feb-2014, 18:54 | #6 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
20-Feb-2014, 21:39 | #7 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
Upa
Enviado desde mi GT-I9100 mediante Tapatalk |
20-Feb-2014, 22:29 | #8 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
21-Feb-2014, 07:57 | #9 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
Upa
21-Feb-2014, 13:38 | #10 |
Lo menos de la 16
21-Feb-2014, 15:02 | #11 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
Mande PM
21-Feb-2014, 15:35 | #12 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
21-Feb-2014, 16:35 | #13 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
alguien mas va a querer su memoria baratus
21-Feb-2014, 17:03 | #14 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
upa
21-Feb-2014, 17:54 | #15 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
22-Feb-2014, 09:29 | #16 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
alguien
22-Feb-2014, 12:19 | #17 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
negociables jovenes
22-Feb-2014, 13:58 | #18 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
22-Feb-2014, 16:11 | #19 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
upa
22-Feb-2014, 19:08 | #20 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
upale
22-Feb-2014, 22:05 | #21 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
22-Feb-2014, 23:45 | #22 |
disfrutando la vida
gratis
23-Feb-2014, 11:42 | #23 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
23-Feb-2014, 15:45 | #24 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
23-Feb-2014, 18:11 | #25 |
ex travianero
vw Rabbit 1982
Tiempo: 1 hr 39 min
No se quede sin la suya varias vendidas
16gb, 8gb, memoria, memorias usb, usb |
