Retroceder   VelocidadMaxima.com > Automovilismo > Teams / Clubs > Toyota Car Club GT
Toyota Car Club GT Toyota Car Club GT
ExclamationEste thread fue creado hace 5714 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
Antiguo 20-Jun-2009, 17:55   #1
ToyoRed
Mod Toyotero
Avatar de ToyoRed
Tiempo: Waiti 10.7s
Lightbulb """Miren esta info 4-EFTE ECU"""
talvez a mas de alguien le sirva
4E-FTE EP91 ECU pinout
part no. 89661-10200
code. 211000-4290
http://i15.photobucket.com/albums/a3...4E-FTEEP91.jpg
Connector 1
1 IPV Vacuum Switching Valve
2 STA Engine Cranking Signal (Starter Switch)
3 IGF Ignition Feedback from the Ignitor-Coil
4 NE Part of the IIA (Intergrated Ignition Assembly) (RPM)
5 G1 Distributor
6 L ECT "L" Selection Signal. Shift Position Switch
7 2 ECT "2" Selection Signal. Shift Position Switch
8 SL ECT Solenoid
9 S2 ECT Solenoid
10 DISC Aux. Control Valve or Idle-Up System Vacuum Switching Valve
11 VSV1 Air Control Vacuum Switching Valve
12 #10 Injector Pulse 1 & 3
13 E02 Computer Ground
14 ~ ~
15 NSW Neutral Starter Switch
16 SP2 No. 2 Vehicle Speed Sensor ECT in Auto-Transmission
17 G- Distributor Crank Angle
18 G2 Distributor
19 DG Check Connector
20 BC Boost Control
21 S1 ECT Solenoid
22 IGT Ignition Timing
23 OD2 Cruise Control Computer
24 E1 Computer Ground
25 #20 Injector Pulse 2 & 4
26 E01 Computer Ground
Connector 2
1 STP Stop Light Switch
2 PIM Pressure Intake Manifold
3 THA Intake Air Temparature
4 THW Water Temparature Signal
5 P Shift Position Switch (Parking)
6 OX Oxygen Sensor (Lambda Sensor)
7 TE2 Check Connector
8 VF Check Connector Outputs
9 E2 Sensor Ground
10 VTA/PSW Throttle Position Sensor
11 VCC Throttle Position Sensor (pin 1)
12 IDL Throttle Position Sensor (Signals ECU throttle position is at idle)
13 M Shift Position Switch
14 KNK Knock Sensor
15 TE1 Check Connector
16 ~ ~
Connector 3
1 +B1 Switched Battery Power (12V)
2 BATT Switched Battery Power (+12V) (EFI Main Relay)
3 CCO Check Connector Outputs
4 FC Circuit Opening Relay (Fuel Cut)
5 AC2 12V To Aircon Computer
6 ACT A/C Cut Control System
7 +B Switched Battery Power (12V)
8 W Warning Light
9 EGW Catalytic Converter Temparature Warning Light (Combination Meter)
10 AC1 A/C Switch Signal System (12V to Aircon Computer)
11 SPD Speed Signal
12 ELS Electrical Load Signal System Taillight Relay
WWW.TOYOTACARCLUBGT.COM
ToyoRed está desconectado   Responder Citando
Antiguo 20-Jun-2009, 21:52   #2
carlosrafa
100% stock :D
Avatar de carlosrafa
Silvia S14
Re: """Miren esta info 4-EFTE ECU"""
buena info, para la hora de hacer un swap y haya que re armar el arnes
carlosrafa está desconectado   Responder Citando
Antiguo 20-Jun-2009, 22:16   #3
@lexts61
vsss :shupala: asdlfjsd
Avatar de @lexts61
patines, cuatro ruedas
Tiempo: 9.20
cabal para hace el arnes
machinita style
@lexts61 está desconectado   Responder Citando
Antiguo 20-Jun-2009, 22:16   #4
2368
Racing Resource
Avatar de 2368
Feedback Score: 337 reviews
bonita info, yo hasta ahorita todo lo que habia visto de ese motor, estaba en japones... asi que ni idea...
2368 está desconectado   Responder Citando
Antiguo 20-Jun-2009, 22:22   #5
alfredo783
Avatar de alfredo783
starlet 95
alfredo783 está desconectado   Responder Citando
Antiguo 21-Jun-2009, 11:44   #6
civer
Toyota Car Club GT
Avatar de civer
ahorita añado el link al thread de informacion tecnica este sirve por si se hace un swap a 4efte
no se permite publicidad en las firmas.
civer está desconectado   Responder Citando
Antiguo 21-Jun-2009, 11:51   #7
jsierra
Avatar de jsierra
buenisima info, esta bien ilustrado incluso por la forma y color de las espigas en fin todo esta nitido, de donde lo sacaste? talvez hay algo de 4age y 4agze, aunque en el foro hay expertos serviria para saber un poco mas........
[SIGPIC][SIGPIC
jsierra está desconectado   Responder Citando
Antiguo 21-Jun-2009, 12:56   #8
truenogtte47
MEMBER
Avatar de truenogtte47
Iniciado por jsierra Ver Mensaje
x 2
truenogtte47 está desconectado   Responder Citando
Antiguo 21-Jun-2009, 17:06   #9
ToyoRed
Mod Toyotero
Avatar de ToyoRed
Tiempo: Waiti 10.7s
y mis creditos laksjdklajsdf
buscando mas info sobre swap para 4age
La franja horaria es GMT -6. Ahora son las 22:57.
Page generated in 0,08079 seconds with 11 queries
